Sphere based calculations for geography don't appear to be faster?
Marco Boeringa
marco at boeringa.demon.nl
Wed Oct 9 02:20:56 PDT 2024
Greg, given the current situation you are right it would be wise to
adjust the Help docs for e.g. ST_Area() etc. and remove the statement
that sphere based calculations are faster.
Out of curiosity, I also posted an issue on the upstream GeographicLib
GitHub repo though, underlying PostGIS's implementation for geography
data type. One of the developers confirmed that with flattening=0
(sphere case), there is no special optimized code path in
GeographicsLib. This confirms Paul's and Regina's statements (although
those were more related to PostGIS itself) that there is no special
treatment for the simpler sphere case.
The developer of GeographicLib did give some interesting suggestions
though, especially the remark about the conversion of data to authalic
latitudes, and using that as input for a possible faster sphere based
implementation, to give a reliable approximation of spheroidal areas. See:
https://github.com/geographiclib/geographiclib/issues/31#issuecomment-2395549269
Marco
Op 2-10-2024 om 13:59 schreef Greg Troxel:
> Marco Boeringa<marco at boeringa.demon.nl> writes:
>> I am not suggesting geographiclib is a bad choice. It may well be the
>> fastest and most efficient implementation out there for doing geodesic
>> calculations. It is just that the current PostGIS Help documentation
>> clearly suggests that switching to sphere based calculations can
>> improve performance at the obvious cost of some less accuracy. And of
>> course it would be interesting to know if a true sphere based
>> implementation could be faster, but maybe nobody bothered to implement
>> one as it can be a special case of spheroidal, IDK?
> In that case, the thing to fix might be the docs.
