Topology - create topology tolerance
Paul Ramsey
pramsey at cleverelephant.ca
Tue Oct 15 08:34:30 PDT 2024
Just stick “inurl:lists.osgeo.org <http://lists.osgeo.org/>” into any google search you run.
P
> On Oct 15, 2024, at 1:18 AM, Michal Seidl <michal.seidl at gmail.com> wrote:
> Hello,
> is there any documentation when and how is topology tolerance parameter used? Despite I have set this tolerance to 0.001m I can found topology elements (nodes, edges) geometry with much more decimal digits?
> https://postgis.net/docs/CreateTopology.html
> Thanks Michal
> P.S. Is there any searchable version of mailing list?
> https://lists.osgeo.org/pipermail/postgis-users/
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20241015/38a21dd1/attachment.htm>
