Update postgis in a replicated PostgreSQL 12 database now with postgis-3
Regina Obe
lr at pcorp.us
Thu Sep 5 10:16:26 PDT 2024
Yes. Running twice second run is supposed to repackage postgis_raster.
If the repackaging works, then to drop raster just do:
DROP EXTENSION postgis_raster;
If drop extension works, no need to run that uninstall_rtpostgis.sql script.
If it doesn’t work then you need to run uninstall_rtpostgis.sql to remove.
Sent: Thursday, September 5, 2024 12:26 PM
To: Andrew Hardy <andrew.hardy at sabstt.com>; postgis-users at lists.osgeo.org; strk at kbt.io
Subject: Re: Update postgis in a replicated PostgreSQL 12 database now with postgis-3
Sandro,
Thanks.
To be completely clear then
Run SELECT postgis_extensions_upgrade(); twice anyway
Even if one ultimately hopes to end up running https://postgis.net/stuff/uninstall_rtpostgis.sql
right?
On Thu, 5 Sept 2024 at 15:15, Sandro Santilli <strk at kbt.io <mailto:strk at kbt.io> > wrote:
> -- I have not yet run this (neither once nor twice) - I was in the process
> in my earlier post of discussing if it would still work given my first
> mistake
Please run it, then report back.
--strk;
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20240905/c43f0f7c/attachment.htm>
