postgis-users Digest, Vol 271, Issue 6
Auberg, Mirko
Mirko.Auberg at btc-it-services.com
Tue Sep 17 01:32:12 PDT 2024
that's seems odd to me.
For PostGIS 3.0, 3.1, 3.2 & 3.3 where no root privileges necessary, because the Setup installed all while through the pg_config File under the PostGIS installation.
I don't want PostGIS Binaries on my "Compile System" under "/usr/local/bin/raster2pgsql'. The installation has to be under /postgres/PGRH8T/backup/compile/postgresql_16.4/compiled_finished/pgsql/.
Execution with sudo can't be the solution.
Regards
-----Ursprüngliche Nachricht-----
Von: postgis-users-request at lists.osgeo.org <postgis-users-request at lists.osgeo.org>
Gesendet: Montag, 16. September 2024 21:00
An: postgis-users at lists.osgeo.org
Betreff: postgis-users Digest, Vol 271, Issue 6
[Sie erhalten nicht h?ufig E-Mails von postgis-users-request at lists.osgeo.org. Weitere Informationen, warum dies wichtig ist, finden Sie unter https://aka.ms/LearnAboutSenderIdentification ]
Send postgis-users mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
https://lists.osgeo.org/mailman/listinfo/postgis-users
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
postgis-users-owner at lists.osgeo.org
When replying, please edit your Subject line so it is more specific than "Re: Contents of postgis-users digest..."
Today's Topics:
1. PostGIS 3.4.x - Error while compile make install (Auberg, Mirko)
2. Re: PostGIS 3.4.x - Error while compile make install
(Jorge Gustavo Rocha)
Message: 1
Date: Mon, 16 Sep 2024 15:38:07 +0000
From: "Auberg, Mirko" <Mirko.Auberg at btc-it-services.com>
To: "postgis-users at lists.osgeo.org" <postgis-users at lists.osgeo.org>
Subject: PostGIS 3.4.x - Error while compile make install
Message-ID:
<FR2P281MB2687318755A942447304112889602 at FR2P281MB2687.DEUP281.PROD.OUTLOOK.COM>
Content-Type: text/plain; charset="us-ascii"
Hello PotGIS Users,
i try to compile PostGIS 3.4.3 with PostgreSQL 16.4.
My configure Option are this:
./configure --with-pgconfig=/postgres/PGRH8T/backup/compile/postgresql_16.4/compiled_finished/pgsql/bin/pg_config --with-geosconfig=/postgres/PGRH8T/backup/compile/postgresql_16.4/compiled_finished/pgsql/usr/bin/geos-config --with-gdalconfig=/postgres/PGRH8T/backup/compile/postgresql_16.4/compiled_finished/pgsql/usr/bin/gdal-config --with-projdir=/usr/proj63/ --with-sfcgal --without-protobuf
OS: RedHat 8
GEOS Version 3.12.2
GDAL: Version 3.9.2
Proj: Version 6.3
Im getting at "make install" following Error.
make -C loader install
make[2]: Entering directory '/postgres/PGRH8T/backup/compile/postgresql_16.4/postgresql_16.4_source/postgis-3.4.3/raster/loader'
/bin/sh ../../libtool --mode=install /usr/bin/install -c raster2pgsql "/usr/local/bin/raster2pgsql"
libtool: install: /usr/bin/install -c raster2pgsql /usr/local/bin/raster2pgsql
/usr/bin/install: cannot create regular file '/usr/local/bin/raster2pgsql': Permission denied
make[2]: *** [Makefile:97: install] Error 1
make[2]: Leaving directory '/postgres/PGRH8T/backup/compile/postgresql_16.4/postgresql_16.4_source/postgis-3.4.3/raster/loader'
make[1]: *** [Makefile:50: install] Error 2
make[1]: Leaving directory '/postgres/PGRH8T/backup/compile/postgresql_16.4/postgresql_16.4_source/postgis-3.4.3/raster'
make: *** [GNUmakefile:25: install] Error 1
Seems like a Bug to me. I have the error just with Version 3.4.x. With older Version is no Problem. Looks like the compiler forgets the pg_config Location an tries to install in the usual OS Path.
Does somebody know the problem or can open a Bug Ticket?
Regards,
Mirko
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20240916/4d3162b1/attachment-0001.htm>
Message: 2
Date: Mon, 16 Sep 2024 17:43:03 +0100
To: postgis-users at lists.osgeo.org
Subject: Re: PostGIS 3.4.x - Error while compile make install
Message-ID: <66e657b2-af33-4d7f-b35f-28ea1bdf673d at di.uminho.pt>
Content-Type: text/plain; charset="utf-8"; Format="flowed"
Hi Mirko,
You need to run the install with root privileges.
sudo make install
Regards,
Jorge
On 16/09/24 16:38, Auberg, Mirko wrote:
> Hello PotGIS Users,
> ./configure
> OS: RedHat 8
> GEOS Version 3.12.2
> GDAL: Version 3.9.2
> Proj: Version 6.3
> Im getting at ?make install? following Error.
> Regards,
> Mirko
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20240916/9a0c5b41/attachment-0001.htm>
Subject: Digest Footer
End of postgis-users Digest, Vol 271, Issue 6
