AW: Install location
    Auberg, Mirko
    Mirko.Auberg at btc-it-services.com
    Tue Sep 17 07:52:47 PDT 2024
thanks for the advice I had to configure bindir and mandir additionally.
After that the make install install everything as expected unter the compile Directory. Thanks.
It's a strange behavior but it works. Thanks. I will test the PostgreSQL Binaries with the PostGIS 3.4 extension in a few days.
Regards
Mirko
-----Ursprüngliche Nachricht-----
Von: Sandro Santilli <strk at kbt.io>
Gesendet: Dienstag, 17. September 2024 16:13
An: Auberg, Mirko <Mirko.Auberg at btc-it-services.com>
Cc: postgis-users at lists.osgeo.org
Betreff: Install location
[Sie erhalten nicht h?ufig E-Mails von strk at kbt.io. Weitere Informationen, warum dies wichtig ist, finden Sie unter https://aka.ms/LearnAboutSenderIdentification ]
On Tue, Sep 17, 2024 at 08:32:12AM +0000, Auberg, Mirko wrote:
> For PostGIS 3.0, 3.1, 3.2 & 3.3 where no root privileges necessary, because the Setup installed all while through the pg_config File under the PostGIS installation.
> I don't want PostGIS Binaries on my "Compile System" under "/usr/local/bin/raster2pgsql'. The installation has to be under /postgres/PGRH8T/backup/compile/postgresql_16.4/compiled_finished/pgsql/.
Try ./configure --bindir=/postgres/PGRH8T/backup/compile/postgresql_16.4/compiled_finished/pgsql/bin
See ./configure --help with more possible tweaks (--prefix coming handy)
--strk;
