Topology - how edit node and edge vertex position
Michal Seidl
michal.seidl at gmail.com
Thu Sep 26 13:11:12 PDT 2024
Hello,
I am trying to figure out, what is correct way to edit
position/coordinates of nodes and edge vertexes.
While updating edge vertexes can be achieved with function
ST_ChangeEdgeGeom() by updating whole geometry.
If I try to update start or end point I get 'SQL/MM Spatial exception -
start node not geometry start point' that is correct by checking the C
code of function.
So how to change position of start or end point of edge? I would expect
some function but I am not able to find it.
Thanks for advice Michal S.
