ST_ClipByBox2D and NaN Coordinates for POLYGON Z
Denis Rykov rykovd at gmail.com
Thu Apr 3 14:58:10 PDT 2025
Thanks for the heads-up!
On Thu, Apr 3, 2025 at 11:52 PM Paul Ramsey <pramsey at cleverelephant.ca>
wrote:
> Oh yep, that’s a positively ancient GEOS (Google cloud?) you really need
> to get a newer one under your PostGIS, or you’ll have all sorts of failures
> in your overlays, etc, that have long since been fixed. GEOS 3.13 is API
> backwards compatible with 3.8 so there’s really no reason not to go with
> the latest.
> P.
> On Apr 3, 2025, at 2:49 PM, Denis Rykov <rykovd at gmail.com> wrote:
> Thanks for the quick response, Paul!
> $ select postgis_full_version();
> POSTGIS="3.5.2 dea6d0a" [EXTENSION] PGSQL="120" GEOS="3.8.0-CAPI-1.13.1 "
> PROJ="6.3.1" LIBXML="2.9.10" LIBJSON="0.13.1" LIBPROTOBUF="1.3.3"
> WAGYU="0.5.0 (I
> nternal)"
> (1 row)
> On Thu, Apr 3, 2025 at 11:45 PM Paul Ramsey <pramsey at cleverelephant.ca>
> wrote:
>> “Works for me”, what’s your version collection?
>> pramsey=# select postgis_full_version();
>>  POSTGIS="3.6.0dev 3.5.0-228-g2c8f40113" [EXTENSION] PGSQL="170"
>> GEOS="3.14.0dev-CAPI-1.20.0" PROJ="9.3.0 NETWORK_ENABLED=ON URL_ENDPOINT=
>> https://cdn.proj.org
>> USER_WRITABLE_DIRECTORY=/Users/pramsey/Library/Application Support/proj
>> DATABASE_PATH=/usr/local/share/proj/proj.db" (compiled against PROJ 9.3.0)
>> GDAL="GDAL 3.9.3, released 2024/12/10 (debug build)" LIBXML="2.9.13"
>> LIBJSON="0.17" LIBPROTOBUF="1.4.1" WAGYU="0.5.0 (Internal)" (core procs
>> from "3.6.0dev 3.5.0-186-g2845d3f37" need upgrade) RASTER (raster lib from
>> "3.5.0 3.5.0-211-g202d59f44" need upgrade) (raster procs from "3.5.0 3.5.0"
>> need upgrade)
>> On Apr 3, 2025, at 2:43 PM, Denis Rykov <rykovd at gmail.com> wrote:
>> Is it expected for ST_ClipByBox2D to return NaN coordinates for 'POLYGON
>> Z' geometries?
>> Here is an example. The following SQL query:
>> SELECT
>>   ST_AsText(
>>     ST_SimplifyPreserveTopology(
>>       ST_ClipByBox2D(
>>         ST_GeomFromText(
>>           'POLYGON Z ((9109727.260586184 7235765.611871982
>> 0,9109793.397475857 7235780.37911723 0,9109880.551536862 7235799.226171476
>> 0,9109912.974452058 7235743.263961895 0,9109949.41754929 7235677.287550647
>> 0,9109986.927785816 7235610.625640362 0,9110029.388466287 7235535.445041807
>> 0,9110063.152192863 7235481.075809712 0,9110058.528985653 7235478.79780619
>> 0,9110066.094453445 7235463.4091950925 0,9110094.816342745
>> 7235418.349932027 0,9110128.716586944 7235357.442269537 0,9110170.311475156
>> 7235283.992565744 0,9110207.570403146 7235217.92016041 0,9110271.536255063
>> 7235090.866183731 0,9110290.55592083 7235042.889807568 0,9110192.389007365
>> 7235014.391634338 0,9110169.194172846 7235007.739006326 0,9109951.366830455
>> 7235432.506918687 0,9109937.453975307 7235459.0955318 0,9109797.566462943
>> 7235663.435298668 0,9109727.260586184 7235765.611871982 0))'
>>         ST_MakeEnvelope(
>>           9108725.486174684, 7235101.049109253,
>>           9111416.069569945, 7237791.632504516
>>       5
>> fails with the 'Geometry contains invalid coordinates' error, but
>> wrapping the geometry in ST_Force2D makes it work.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20250403/768d7512/attachment.htm>
