Why does the raster type not have send/receive defined?
lr at pcorp.us lr at pcorp.us
Tue Apr 8 08:15:53 PDT 2025
I think it’s because postgis raster is not an OGC standard or any kind of standard outside of PostGIS so there hasn’t been much need for it.
For example if you wanted to backup your postgis raster table, you’d just use standard pg_dump / pg_restore tools.
Most use cases beyond that are importing from a different raster format or exporting to a different raster format which functions
https://postgis.net/docs/en/RT_ST_FromGDALRaster.html
and https://postgis.net/docs/en/RT_ST_AsGDALRaster.html
as well as the raster2pgsql commandline tool.
From: Lukas Panhirsch via postgis-users <postgis-users at lists.osgeo.org>
Sent: Tuesday, April 8, 2025 9:28 AM
To: postgis-users at lists.osgeo.org
Subject: Why does the raster type not have send/receive defined?
Hello,
I haven't used this mailing list before and couldn't figure out how to search in the archives, so I apologize if this has been answered before.
Is there any specific reason why the raster type does not have the send/receive functions in its SQL type definition?
The geometry type has these defined as conversions to/from EWKB, which are equivalent to ST_AsEWKB/ST_GeomFromEWKB if I understand correctly.
Equivalent (E?)WKB conversion functions exist for rasters in the form of (RT_)ST_AsBinary/ST_RastFromWKB, but have to be called explicitly.
I would like to use PostgreSQL features like COPY ... WITH BINARY with rasters, but it seems this is preventing me from doing so.
Sincerely,
Lukas
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20250408/c75a29f6/attachment.htm>
