[a little bit OT] calculating X,Y from latitude and longitude
Luca Bertoncello
lucabert at lucabert.de
Tue Aug 19 03:38:57 PDT 2025
Am 19.08.2025 12:25, schrieb Greg Troxel:
Hi Greg,
> If you aren't using postgis, then your question is really off topic!
I know it and I already said it at the beginning...
> In that case, you should use gdal, which also uses proj. And, it can
> read/write postgis.
> https://gdal.org/en/stable/
> and in particular the ogr2ogr program is useful.
I need to do it in my program, and unfortunately there is no actual
GDAL-library for PHP.
Any other idea where can I get some sample code which works?
Thanks
Luca Bertoncello
(lucabert at lucabert.de)
