Query on why ST_3DDifference running slowly
Neil Underhill
neil.underhill at gmail.com
Tue Aug 19 07:39:50 PDT 2025
My use case: I am using ST_3DDifference to calculate the net volume of a
dam shape (an extruded triangle) with a terrain source (Delaunay triangles
extruded to make a solid).
My query: The following statement runs slowly (nearly 10 minutes for a
single row dam / terrain intersection):
*SELECT SELECT ST_3DDifference(dp.geom, vp.geom) FROM dam_polysurf dp,
valley_polysurf vp WHERE dp.id <http://dp.id> = 1 AND vp.id <http://vp.id>
= 1*
See Stack Overflow query in link below for details.
I have tested a similar statement using the QSFCGAL plugin with
"Intersection 3D", which takes a similar length of time as in PostGIS with
ST_3dIntersection (ST_3ddifference is not available currently in QSFCGAL).
So this suggests that the issue is to do with the underlying SFCGAL code
rather than PostGIS.
However I have posted this query on
https://stackoverflow.com/questions/79456705/st-3ddifference-in-postgis-taking-several-minutes-to-run-on-two-polyhedralsrufac
and also emailed one of the tema at Oslandia, but no response.
I could not find any insight into how the underlying "ST_3ddifference"
algorithm works on the https://sfcgal.gitlab.io/SFCGAL/ website.
Now throwing it out to the PostGIS mailing list, in case others have come
across with this, or have some ideas to improve it (e.g. how to reduce the
number of faces in the valley_polysurf row).
Thanks,
Neil
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20250819/603d4ea0/attachment.htm>
