Difference in behavior of AddGeometryColumn change in behavior between 3.5.2 and 3.5.3? SRID is listed as unknown when querying Geometry_Columns instead of the specified SRID
Regina Obe
lr at pcorp.us
Mon Aug 25 12:15:01 PDT 2025
We did remove constraint support in geometry_columns where and since you are
using constraints that would do it.
Though I thought we did that in upcoming PostGIS 3.6.0 not PostGIS 3.5.3,
but I guess I was mistaken. It was done in 3.5.3.
https://trac.osgeo.org/postgis/ticket/5829
Any reason you can't switch to typmod. The constraint logic has a number of
issues, it is slower to parse than typmod and has caused people issues over
the years as it traps other constraints causing issues as you can see in
the above ticket.
The workaround for this if you need the old behavior is to use the
geometry_columns view definition from 3.5.2
Thanks,
Regina
From: Michael Downey via postgis-users <postgis-users at lists.osgeo.org>
Sent: Monday, August 25, 2025 1:11 PM
To: postgis-users at lists.osgeo.org
Cc: Jonathan Shim <JShim at esri.com>; Ale Raza <araza at esri.com>; Yung-Ting
Chen <ychen at esri.com>; Neeta Reddy <nreddy at esri.com>; Justin Muise
<JMuise at esri.com>
Subject: Difference in behavior of AddGeometryColumn change in behavior
Windows 17.6, 16.10,
PostGIS 3.5.3
For some reason I did not see this when I started testing 3.5.3 a couple of
months ago. After I removed the earlier 3.5.2 and reinstalled 3.5.3, saw the
query return an unknonw SRID instead of the stated one.
DROP TABLE map.t1;
CREATE TABLE map.t1 (
OBJECTID SERIAL NOT NULL,
PKEY INTEGER,
PRIMARY KEY ( OBJECTID ) );
SELECT public.AddGeometryColumn ('map', 't1', 'shape', 4326,
upper('POINT'), 2, false);
addgeometrycolumn
map.t1.shape SRID:4326 TYPE:POINT DIMS:2
SELECT f_table_schema AS schema, f_table_name AS table, f_geometry_column AS
column, coord_dimension AS Dimension, srid FROM public.geometry_columns;
PostGIS 3.5.2
schema | table | column | dimension | srid
map | t1 | shape | 2 | 4326
PostGIS 3.5.3
map | t1 | shape | 2 | 0
But describe table looks fine:
\d t1
Table "map.t1"
Column | Type | Collation | Nullable | Default
objectid | integer | | not null |
nextval('t1_objectid_seq'::regclass)
pkey | integer | | |
shape | geometry | | |
Indexes:
"t1_pkey" PRIMARY KEY, btree (objectid)
Check constraints:
"enforce_dims_shape" CHECK (st_ndims(shape) = 2)
"enforce_geotype_shape" CHECK (geometrytype(shape) = 'POINT'::text OR
shape IS NULL)
"enforce_srid_shape" CHECK (st_srid(shape) = 4326)
Thanks,
Michael
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20250825/f9670849/attachment.htm>
