Problem with ST_NRings
Marco Boeringa marco at boeringa.demon.nl
Tue Dec 2 10:57:53 PST 2025
As part of a larger workflow, I am using a custom PostgreSQL function
that depends on ST_NRings, and is used to create a MATERIALIZED VIEW.
This has worked flawlessly until recently. I now ran into an issue with
the error message below. Going over my own code calling the custom
function that includes the ST_NRings call, I just cannot see any recent
code change made by myself explaining this sudden error. This part of
the code has been stable for quite a while.
As input to the custom function, WGS1984 OpenStreetMap data is used,
stored as  'geometry' type. There are actually explicit type casts in
the code as well, so even that part of the error message I cannot
explain for now.
My question: has there been any change to ST_NRings in a recent update
of PostGIS (3.6.0 or 3.6.1?), that might explain this error? E.g. should
the 'public' be in this error message at all, I would have expected
"ERROR:  function st_nrings(geometry) does not exist"?
Marco
ERROR:  function st_nrings(public.geometry) does not exist
LINE 8:    WHEN ST_NRings($1) = 1 THEN $1
HINT:  No function matches the given name and argument types. You might
need to add explicit type casts.
