Trying to build postgis on centos10
Regina Obe
lr at pcorp.us
Sat Feb 1 21:37:35 PST 2025
Hmm I would have expected that to work. To be honest, I've never tried building postgis from source on Centos. I just always use the packages from yum.postgresql.org
I suppose it could be for whatever reason the paths aren't set and pointing at pg_config is not sufficent. When I build under windows, I always set my paths.
Before starting your compile try
export PATH=/usr/pgsql-16/bin:/usr/pgsql-16/lib:$PATH
> -----Original Message-----
> From: Niklas Baudy <niklas.baudy at vanniktech.de>
> Sent: Saturday, February 1, 2025 3:28 AM
> To: postgis-users at lists.osgeo.org
> Subject: Trying to build postgis on centos10
> Hey,
> I've never used such a mailing list so please let me know if I'm using this
> incorrectly. I'm trying to build postgis on centos10 and I'm stuck, these are my
> commands:
> dnf config-manager --set-enabled crb
> dnf install perl-IPC-Run
> dnf install postgresql16-devel gcc geos-devel proj-devel gdal-devel json-c-devel
> libxml2-devel wget https://postgis.net/stuff/postgis-3.5.3dev.tar.gz
> tar -xvzf postgis-3.5.3dev.tar.gz
> rm postgis-3.5.3dev.tar.gz
> cd postgis-3.5.3dev
> ./configure --with-pgconfig=/usr/pgsql-16/bin/pg_config
> --with-gdalconfig=/usr/bin/gdal-config
> --with-geosconfig=/usr/bin/geos-config
> It fails with: configure: error: could not find libpq.
> > find / -name 'libpq.so*'
> /usr/pgsql-16/lib/libpq.so.5.16
> /usr/lib64/libpq.so.5
> /usr/lib64/libpq.so
> /usr/lib64/libpq.so.5.17
> How can I let the configure script know about these locations?
> Thanks!
> -niklas
