Help creating "corridors"
Luca Bertoncello lucabert at lucabert.de
Thu Feb 6 22:07:38 PST 2025
Am 06.02.2025 um 23:08 schrieb Simon SPDBA Greener:
Hi Simon
> 10 LOWI - Mieminger Plateau - Fernpass - Reutte - Pfronten - EDMK 4700
> ... have a start and end airport with "waypoints" in between that look
> like topographic features or town names.
> You need to get a latitude/longitude for these intermediate points from
> another dataset - you mentioned OpenStreetMap - and then import those as
> well.
> *The work you have to do is to create "routes" from these two input
> sources.*
Thank you very much for your help!
I'll check it and search the data, then I'll try the queries.
I answer here a question you send me by private mail, since your mail
server has blaclisted mine... :(
> Now what does this mean? Does the flight follow the Autobahn? If so,
> that is a complex set of points to include in the flight path.
Yes, since Austria have Alps, you cannot fly wherever you want, but you
must follow the valleys.
In this case, you will really fly over the streets (Autobahn is highway
street).
Regards
Luca Bertoncello
(lucabert at lucabert.de)
