Intersects error on filtered and casted geometry type
MONTICOLO Julien
Julien.MONTICOLO at strasbourg.eu
Fri Feb 7 06:04:07 PST 2025
Hello,
Bellow my case and the steps to reproduce :
/* About my database */
SELECT VERSION();
-- PostgreSQL 16.4, compiled by Visual C++ build 1941, 64-bit
SELECT POSTGIS_VERSION();
-- 3.4 USE_GEOS=1 USE_PROJ=1 USE_STATS=1
/* Create a table with a generic geometry column with french CC48 3948 SRID */
CREATE TEMP TABLE temp_geometry_tab (
id INTEGER NOT NULL PRIMARY KEY GENERATED BY DEFAULT AS IDENTITY,
geom GEOMETRY(GEOMETRY, 3948)
-- CREATE TABLE
-- Query returned successfully in 117 msec.
/* Add two rows, one with a point geometry and another with multipolygon */
INSERT INTO temp_geometry_tab (geom) VALUES
('POINT (2049346 7276066)'),
('MULTIPOLYGON (((2049302 7274650,2050712 7276342,2051981 7276013,2050865 7275954,2049795 7274791,2049948 7274050,2049302 7274650)))')
-- INSERT 0 2
-- Query returned successfully in 71 msec.
/* Create a view to filter the point geometries and cast them into points */
CREATE TEMP VIEW temp_geometry_view AS
SELECT
id,
geom::GEOMETRY(POINT, 3948)
FROM temp_geometry_tab
WHERE ST_GeometryType(geom) IN ('ST_Point')
-- CREATE VIEW
-- Query returned successfully in 83 msec.
/* When I try to intersect the view geometry, an error occurs as if I query the base table */
SELECT id
FROM temp_geometry_view
WHERE geom && ST_MakeEnvelope(2041534,7271489,2059551,7281479,3948)
-- ERROR: Geometry type (MultiPolygon) does not match column type (Point)
-- SQL state: 22023
/* When I try to query the first view with and additional filter it works */
SELECT
id,
WHERE
AND geom && ST_MakeEnvelope(2041534,7271489,2059551,7281479,3948)
-- id: 1 | geom: 01010000206C0F00000000000042453F410000008088C15B41
Is-it normal that the filter consider the whole base table with multipolygon geometries while only point type geometries are filtered in the queried view?
Regards,
Julien Monticolo
Ce message est établi à usage exclusif de son destinataire.
Toute utilisation ou diffusion, partielle ou totale, doit être
préalablement autorisée.
Tout message électronique est susceptible d'altération et son intégrité
ne peut être assurée. L'expéditeur décline toute responsabilité au titre
de ce message s'il a été modifié ou falsifié.
Si vous n'êtes pas destinataire de ce message, merci de le détruire et
d'avertir l'expéditeur.
Ville et Eurométropole de Strasbourg
