Missing results after adding index
Kjell Kvinge kjell at easyconnect.no
Mon Feb 24 10:41:49 PST 2025
Hi.
I notice different behaviour in postgis 3.5 compared to previous versions.
When I add an index to a table containing extents, the result from query
disappears
Example to isolate this issue:
# starting docker image postgis/postgis:17-3.5
create temp table test (street text, extent geometry(Polygon,32633));
insert into test values
('Knøsesmauet','0103000020797F0000010000000500000010B2468761BDDFC06390523AA1B0594110B2468761BDDFC030554D9BC3B0594107992AF50799DFC030554D9BC3B0594107992AF50799DFC06390523AA1B0594110B2468761BDDFC06390523AA1B05941');
set enable_seqscan=false;
SELECT street
FROM test
WHERE ST_DFullyWithin(
    ST_SetSRID(ST_GeomFromText('POINT(-32356 6734606)'), 32633),
    extent,
    1700
-- we get the street as expected.
-- we add an index
create index ON test using gist (extent );
now, running the same query returns zero rows.
# starting docker image postgis/postgis:17-3.4
Now, both queries returns expected street.
Is this a bug I have stumbled upon? or am I missing something here?
Thank you.
br.
Kjell Kvinge.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20250224/5c9ccf2b/attachment.htm>
