Missing results after adding index
Kjell Kvinge kjell at easyconnect.no
Mon Feb 24 15:51:45 PST 2025
Thank you for your reply.
I'm really in deep waters here, but I have tried to figure out when this
behaviour changed.
It seems to be around this patch
https://github.com/postgis/postgis/commit/f5d6c10b7de4cc6cac4e809d495aa4ad25ca4743
Does that make sense?
Thank you.
man. 24. feb. 2025 kl. 19:54 skrev Paul Ramsey <pramsey at cleverelephant.ca>:
> Clearly the index test associated with that query is not consistent with
> the full calculation, so yeah, seems like a bug.
> > On Feb 24, 2025, at 10:41 AM, Kjell Kvinge <kjell at easyconnect.no> wrote:
> > Hi.
> > I notice different behaviour in postgis 3.5 compared to previous
> versions.
> > When I add an index to a table containing extents, the result from query
> disappears
> > Example to isolate this issue:
> > # starting docker image postgis/postgis:17-3.5
> > create temp table test (street text, extent geometry(Polygon,32633));
> > insert into test values
> ('Knøsesmauet','0103000020797F0000010000000500000010B2468761BDDFC06390523AA1B0594110B2468761BDDFC030554D9BC3B0594107992AF50799DFC030554D9BC3B0594107992AF50799DFC06390523AA1B0594110B2468761BDDFC06390523AA1B05941');
> > set enable_seqscan=false;
> > SELECT street
> > FROM test
> > WHERE ST_DFullyWithin(
> >     ST_SetSRID(ST_GeomFromText('POINT(-32356 6734606)'), 32633),
> >     extent,
> >     1700
> > -- we get the street as expected.
> > -- we add an index
> > create index ON test using gist (extent );
> > now, running the same query returns zero rows.
> > # starting docker image postgis/postgis:17-3.4
> > Now, both queries returns expected street.
> > Is this a bug I have stumbled upon? or am I missing something here?
> > Thank you.
> > br.
> > Kjell Kvinge.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20250225/977f6829/attachment.htm>
