Do you use PostGIS BRIN?
Regina Obe lr at pcorp.us
Mon Jan 6 12:41:23 PST 2025
Thanks for the input Arthur.
Much appreciated,
Regina
Sent: Monday, January 6, 2025 3:16 PM
To: Regina Obe <lr at pcorp.us>
Subject: Re: Do you use PostGIS BRIN?
Always have used GiST index, never BRIN.
I do a lots of DB audit for many clients and I have never seen any use of BRIN index.
I think that this is not really used and maybe only by specific users with specific needs (for speed and space maybe).
Best regards !
Arthur Bazin
	We are all made of star stuff - Carl Sagan
Pensez à la planète, merci de n'imprimer ce mail que si cela est vraiment nécessaire
Le dim. 5 janv. 2025 à 10:06, Regina Obe <lr at pcorp.us <mailto:lr at pcorp.us> > a écrit :
We are thinking of removing BRIN support in PostGIS because it has a serious
bug as discussed here.
https://lists.osgeo.org/pipermail/postgis-devel/2025-January/030457.html
and here - https://trac.osgeo.org/postgis/ticket/5564
that currently causes crashes during Index building.
The two options on the table are:
1) Fix the issue
2) Remove BRIN Support
I'm leaning toward the removal of BRIN support because I see no point
carrying the technical baggage of continuously supporting BRIN and testing
it
if very very few people are using it.  Yes this will be a breaking change
for those that use it.
Thanks,
Regina
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20250106/16659824/attachment.htm>
