Qgis/Postgis : Multi Union (25 polygonal layers)
celati Laurent laurent.celati at gmail.com
Fri Jul 11 03:22:39 PDT 2025
 Good afternoon,
Thanks so much for your message.
I succeed in executing a postgis script without error message. It is
working.
However, i notice a lack of  reliability/stabilization. Because when I've
rerun the same process several times, i never end up with exactly the same
number of features in my intermediate/final result tables.
I'm taking the liberty to share you the sql script.
The screenshot compares the number of objects for test v1 and test v2,
(which are identical tests). We can see that there is a difference in the
res_final table, but also in the res table. I ran several tests agai. Still
with different numbers of objects for the res and res_final tables. Often
with larger differences than the one shown in the screenshot.
Number of entities for each table:
*Test 1*:
layer_union table: 1026194
res table : 1462661
 res_assoc table : 1462661
 res_final table : 1462661
*Test 2*
 layer_union table : 1026194
res table 1462645
 res_assoc table : 1462645
 res_final table : 1462635
I share below/and attach the script :
--Import all shp in postgis db
-- union ALL des geom et attributs des 28 data sources dans une seule table
drop table if exists layer_union;
create table layer_union as
select inrae_2014.data_id, inrae_2014.geom from inrae_2014 UNION ALL
select aesn_2006.data_id, aesn_2006.geom from aesn_2006 UNION ALL
select aesn_2019.data_id, aesn_2019.geom from aesn_2019 UNION ALL
--(...)etc.
-- res table
drop table if exists res;
create table res as
with tmp as
(select st_union(ST_Force2D(st_boundary(geom))) as geom from layer_union
select (st_dump(st_collectionextract(st_polygonize(geom), 3))).path[1] as
id,
3))).geom::geometry(polygon, 2154) as geom
from tmp;
-- res table id unique
alter table res add column res_id int generated always as identity primary
key;
-- res table index on pointOnSurfacee
create index on res using gist (st_pointOnSurface(geom));
analyze res;
-- res_assoc table
--JOIN simple for filter polygons without link with input polygons (for
instance : holes for data input)
drop table if exists res_assoc;
create table res_assoc as
select res.res_id, array_agg(l.data_id) as data_id_ori, count(distinct
l.data_id) as num_sources
from res join layer_union l on st_contains(l.geom,
st_pointonsurface(res.geom))
group by res.res_id;
-- res_assoc table : index creation
create index on res_assoc(res_id);
analyse res_assoc;
----cleaning: we remove from the res table the polygons that did not match
in res_assoc:
-- these are polygons representing holes in the input layers
delete from res
where not exists (
select null
from res_assoc ra
where ra.res_id = res.res_id);
-- -- Final table with the new polygons and the source polygon information,
as a join:
-- Much faster to create a table than to update the res table (after adding
the desired columns).
drop table if exists res_final;
create table res_final as
select ra.res_id, data_id_ori, num_sources, geom::geometry(polygon, 2154)
as geom
from res_assoc ra join res r on ra.res_id = r.res_id;
Thanks so much
Le mar. 8 juil. 2025 à 02:54, <snorris at hillcrestgeo.ca> a écrit :
> Here is working example of Martin's suggestion, for a job that sounds
> fairly similar:
> https://github.com/bcgov/harvest-restrictions/blob/main/sql/overlay.sql
> On Jul 7, 2025, at 4:45 PM, Martin Davis <mtnclimb at gmail.com> wrote:
> I'd characterize your use case as "Overlay of overlapping polygonal
> datasets".  The basic state-of-the art for solving this using PostGIS is
> still the solution Paul outlined in
> https://blog.cleverelephant.ca/2019/07/postgis-overlays.html (or see
> https://dr-jts.github.io/postgis-patterns/overlay/overlay.html#count-overlap-depth-in-set-of-polygons
> for more ideas).
> Basically, you node and polygonize to make a flat coverage, and then join
> back to the parent layers to determine attribution (including counts).
> Doing this in a single query might be slow for very large datasets like
> yours, though.  You might be able to partition your large dataset and run
> smaller queries, possibly in parallel.  Also, it might be better to overlay
> the small layers first, and then overlay that with the big layer.  And if
> you don't care about overlaps in the big layer (or if there are none), that
> makes it much easier, since you can process each big-layer polygon
> independently (and ideally in parallel).
> On Mon, Jul 7, 2025 at 1:16 PM celati Laurent <laurent.celati at gmail.com>
> wrote:
>> Dear all,
>> I'm working with QGIS and PostGIS. As input, I have 25 polygonal layers
>> covering a large area (multicities area). One of these data is a very large
>> dataset (1 million objects). The other 24 are much smaller (a maximum of a
>> hundred objects).
>> For information, I should point out that some of these polygonal datasets
>> are in "multi-part features" mode and others in "single-part features"
>> mode. I imagine this may ultimately have a slight impact on the
>> method/result. These 25 polygonal .shp files have highly variable,
>> non-homogeneous/non-harmonized data structures. Each layer has a "data_id"
>> field that allows  to define/link/reference, for each feature, its
>> membership in the layer. For example, all values in the "data_id" field for
>> the first layer have a value of '1'. For the second layer, the field values
>> are '2', etc.
>> My goal would be to be able to apply/adapt the existing QGIS
>> geoprocessing tool called "Multiple Union":
>> https://docs.qgis.org/3.40/en/docs/user_manual/processing_algs/qgis/vectoroverlay.html#union-multiple
>> Below a screenshot from the QGIS documentation :
>> <image.png>
>> My goal would be to have an output file:
>>    -  Which would be the result of the union/overlay of the 25 input
>>    data. To use the terms of the QGIS documentation, the processing should
>>    check for overlaps between features within the 25 layers and create
>>    separate features for the overlapping and non-overlapping parts. This
>>    "multiple union" geoprocessing seems interesting for my goal where there is
>>    no overlap (a, NULL; b, NULL; c, NULL).
>>    - For areas where there is an overlap, the QGIS union geoprocessing
>>    creates as many identical overlapping features as there are features
>>    participating in this overlap. This doesn't bother me. But since,
>>    ultimately, I'd like a field in the result/output file to allow, for each
>>    feature, to retrieve the list of input layers that participate/contribute
>>    to this result feature (in order to retrieve the origin/source of the
>>    data). I was wondering/thinking it might be better if only one feature was
>>    created per overlapping area?
>>    -  I'd like a field in the result file to allow, for each feature, to
>>    retrieve the list of input layers that participate/contribute to this
>>    result feature. In order to retrieve the origin/source of the data.
>>    - Ideally, a field that allows you to retrieve the number (COUNT) of
>>    layers that contribute to this feature (at least 1 layer, at most 25
>>    layers).
>>    - Regarding the non-geometric attributes/fields, I would like to be
>>    able to specify the selection/define the list of fields I ultimately want
>>    to keep. I don't want to keep all of the fields, but rather just some of
>>    the fields for each of the 25 input layers.
>> I imagine it's recommended to do this processing in PostGIS rather than
>> QGIS? I can, if necessary, import my 25 SHP files into a PostGIS database.
>> I also imagine it's important to keep in mind that the "multi-part
>> features" / "single-part pieces/features" mode of the input layers can
>> affect the result. If I'm using a PostGIS query, I was thinking it might be
>> helpful to force all features to be in single-part mode (using the PostGIS
>> 'st_dump' function?).
>> In advance, Thanks so much for your help, guidance.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20250711/5ddb9645/attachment.htm>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20250711/5ddb9645/attachment.obj>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20250711/5ddb9645/attachment.jpg>
