Issue with st_estimatedextent function ??
Paul Ramsey pramsey at cleverelephant.ca
Wed Nov 19 10:36:00 PST 2025
I cannot replicate this bug on my PostGIS 3.5.5dev environment, probably
because the issue is already fixed as of 3.5.3
https://github.com/postgis/postgis/blob/stable-3.5/NEWS#L66
https://trac.osgeo.org/postgis/ticket/5819
I think you probably need a maintenance upgrade.
ATB,
P
On Wed, Nov 19, 2025 at 9:21 AM Bo Victor Thomsen <
bo.victor.thomsen at gmail.com> wrote:
> Hi list -
> I'm using Postgres/Postgis as a data repository for QGIS - and it normally
> just works.. However I'm getting errors with tables having long names, for
> example:
> * fdc_results.bygningskade_stormflod_rcp85_2100_t100_ssp3_7_0_20251119164
> (Schema-name length: 11, table-name length: 59)
> I have tracked the issue using the log facility in QGIS. It shows, that
> QGIS intermittently executes a SQL command:
> *SELECT
> st_estimatedextent('fdc_results','bygningskade_stormflod_rcp85_2100_t100_ssp3_7_0_20251119164','geom')*
> which results in an error: *ERROR: invalid name syntax*
> If I change the table name to:
> *fdc_results.bygningskade_stormflod_rcp85_2100_t100_ssp3_7_0   *(Schema-name
> length: 11, table-name length: 47)
> the error disappears.
> I've done some testing and could replicate the error (and non-error)
> situation in PGAdmin
> Further testing shows that if the sum of the character lengths of the
> schema- and table-name is larger than 58 the function will stop with an
> error. Otherwise it returns a result like:
> "BOX(716701.25 6167151,720533.9375 6174220)"
> It's my understanding, that the maximum length of a tablename in
> PostgreSQL is 63. This same limit applies for every type of identifier in
> Postgres. Am I wrong to assume this? Or is there an issue with name lengths
> in the PostGIS st_estimatedextent  function??
> (It might be a coincidence but if you express the tablename like this :
> *"**fdc_results"."bygningskade_stormflod_rcp85_2100_t100_ssp3_7_0**", *the
> total length is 63)
> PostgreSQL version: "PostgreSQL 17.4 on x86_64-windows, compiled by
> msvc-19.42.34436, 64-bit"
> PostGIS version: "3.5 USE_GEOS=1 USE_PROJ=1 USE_STATS=1"
> Med venlig hilsen / Best regards
> Bo Victor Thomsen
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20251119/e809a969/attachment.htm>
