Issue with st_estimatedextent function ??
Bo Victor Thomsen bo.victor.thomsen at gmail.com
Wed Nov 19 11:44:17 PST 2025
Hi Paul -
And thank /you/ for the very quick answer ! I followed you advice and
upgraded to PostGIS 3.5.3. And lo and behold: It worked !!
(And I'm sorry for /not/ looking in PostGIS bug-tracker before blasting
out unnecessary mails to the list - and wasting your time) .
Med venlig hilsen / Best regards
Bo Victor Thomsen
On 19/11/2025 19.36, Paul Ramsey wrote:
> I cannot replicate this bug on my PostGIS 3.5.5dev environment,
> probably because the issue is already fixed as of 3.5.3
> https://github.com/postgis/postgis/blob/stable-3.5/NEWS#L66
> https://trac.osgeo.org/postgis/ticket/5819
> I think you probably need a maintenance upgrade.
> ATB,
> P
> On Wed, Nov 19, 2025 at 9:21 AM Bo Victor Thomsen
> <bo.victor.thomsen at gmail.com> wrote:
>     Hi list -
>     I'm using Postgres/Postgis as a data repository for QGIS - and it
>     normally just works.. However I'm getting errors with tables
>     having long names, for example:
>     fdc_results.bygningskade_stormflod_rcp85_2100_t100_ssp3_7_0_20251119164
>     (Schema-name length: 11, table-name length: 59)
>     I have tracked the issue using the log facility in QGIS. It shows,
>     that QGIS intermittently executes a SQL command:
>     /*SELECT
>     st_estimatedextent('fdc_results','bygningskade_stormflod_rcp85_2100_t100_ssp3_7_0_20251119164','geom')*/
>     which results in an error: *ERROR: invalid name syntax*
>     If I change the table name to:
>     /*fdc_results.bygningskade_stormflod_rcp85_2100_t100_ssp3_7_0
>     */(Schema-name length: 11, table-name length: 47)
>     the error disappears.
>     I've done some testing and could replicate the error (and
>     non-error) situation in PGAdmin
>     Further testing shows that if the sum of the character lengths of
>     the schema- and table-name is larger than 58 the function will
>     stop with an error. Otherwise it returns a result like:
>     "BOX(716701.25 6167151,720533.9375 6174220)"
>     It's my understanding, that the maximum length of a tablename in
>     PostgreSQL is 63. This same limit applies for every type of
>     identifier in Postgres. Am I wrong to assume this? Or is there an
>     issue with name lengths in
>     the PostGIS st_estimatedextent/**/ function??
>     (It might be a coincidence but if you express the tablename like
>     this :
>     /*"*//*fdc_results"."bygningskade_stormflod_rcp85_2100_t100_ssp3_7_0*//*",
>     */the total length is 63)
>     PostgreSQL version: "PostgreSQL 17.4 on x86_64-windows, compiled
>     by msvc-19.42.34436, 64-bit"
>     PostGIS version: "3.5 USE_GEOS=1 USE_PROJ=1 USE_STATS=1"
>     Bo Victor Thomsen
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20251119/2d74640c/attachment.htm>
