different results for ST_Relate with 3 parameters compared to those for ST_Relate with 2 parameters
Paul Ramsey
pramsey at cleverelephant.ca
Thu Oct 16 09:25:41 PDT 2025
Arg, found it. How old am I? Old enough not to remember this fix from, not
YEARS ago, but only months ago.
https://trac.osgeo.org/postgis/ticket/5938
The interaction between the new "cacheable relate" code and the need for
stable operand order for the relate pattern match function generates these
issues, and it's not platform specific, just version specific.
Unfortunately the version of PostGIS 3.5 that fixes this issue... is not
yet released. 3.5.4 will include this fix. As will 3.6.1. My habit of
running and testing off the latest stable branch bit me here, if I was
testing your exact release I would have seen the error immediately.
P.
On Wed, Oct 15, 2025 at 8:25 PM Regina Obe <lr at pcorp.us> wrote:
> Antonio,
> I can replicate your issue with PG17 on windows
> POSTGIS="3.5.3 3.5.3" [EXTENSION] PGSQL="170" GEOS="3.13.1-CAPI-1.19.2"
> PROJ="8.2.1 NETWORK_ENABLED=OFF URL_ENDPOINT=
> USER_WRITABLE_DIRECTORY=C:\Windows\ServiceProfiles\NetworkService\AppData\Local/proj"
> (compiled against PROJ 8.2.1) LIBXML="2.12.5
> " LIBJSON="0.12" LIBPROTOBUF="1.2.1" WAGYU="0.5.0 (Internal)"
> However the PG18 3.6.0 windows package behaves correctly:
> PG18 3.6.0 - POSTGIS="3.6.0 3.6.0" [EXTENSION] PGSQL="180"
> GEOS="3.14.0-CAPI-1.20.4" SFCGAL="SFCGAL 2.2.0, CGAL 6.0.1, BOOST 1.88.0"
> USER_WRITABLE_DIRECTORY=C:\Users\Administrator\AppData\Local/proj"
> (compiled again
> st PROJ 8.2.1) GDAL="GDAL 3.9.2, released 2024/08/13 GDAL_DATA not found"
> LIBXML="2.12.5" LIBJSON="0.12" LIBPROTOBUF="1.2.1" WAGYU="0.5.0 (Internal)"
> TOPOLOGY RASTER
> There are many things changed between the building of the windows 3.5.3
> and the 3.6.0 packages
> e.g. the GEOS was upgraded, I’m compiling with a newer GCC version , and
> of course PostGIS is newer.
> I’m planning to release PostGIS 3.6.1 for PostgreSQL 17, but skipping
> PostGIS 3.6.0 since I have some minor packaging issues to address first and
> PostGIS 3.6.1 is probably less than a month away.
> But we’ll try to figure out what piece is the culprit here.
> *From:* Paul Ramsey via postgis-users <postgis-users at lists.osgeo.org>
> *Sent:* Wednesday, October 15, 2025 6:32 PM
> *To:* Antonio Valanzano <anvalanz at gmail.com>
> *Cc:* postgis-users at lists.osgeo.org
> *Subject:* Re: different results for ST_Relate with 3 parameters compared
> One more sorry!
> SELECT
> ST_Relate(a.geom, b.geom), ST_Relate(a.geom, b.geom, '1FF00F212')
> FROM
> (VALUES
> ('LINESTRING (170 290, 205 272)'),
> ('LINESTRING (120 215, 176 197)'),
> ('LINESTRING (120 215, 176 197)')) AS a(geom),
> (VALUES ('POLYGON ((100 200, 140 230, 180 310, 280 310, 390 270, 400 210,
> 320 140, 215 141, 150 170, 100 200))')) AS b(geom);
> On Wed, Oct 15, 2025 at 3:11 PM Antonio Valanzano <anvalanz at gmail.com>
> wrote:
> Here are the results
> SELECT
> FROM
> (VALUES ('LINESTRING (170 290, 205 272)'),('LINESTRING (120 215, 176
> 197)')) AS a(geom),
> -- 2 rows
> "st_relate" "st_relate-2"
> "1FF00F212" true
> "1FF00F212" false
> Il giorno mer 15 ott 2025 alle ore 23:22 Paul Ramsey <
> pramsey at cleverelephant.ca> ha scritto:
> Thanks for continuing to try stuff. What does this example return?
> SELECT
> FROM
> 197)')) AS a(geom),
> On Wed, Oct 15, 2025 at 1:29 PM Antonio Valanzano <anvalanz at gmail.com>
> wrote:
> Dear Paul
> here are the results with the new linestrings as you suggested
> SELECT
> d.id,
> ST_Relate(d.geom, l.geom) as patternMatrix
> FROM docks as d, lakes as l
> WHERE ST_Relate(d.geom, l.geom, '1FF00F212') = true;
> -- 1 row
> "id" "patternmatrix"
> 7 "1FF00F212"
> SELECT
> d.id,
> WHERE ST_Relate(d.geom, l.geom) = '1FF00F212';
> -- 4 rows
> 7 "1FF00F212"
> 8 "1FF00F212"
> 12 "1FF00F212"
> 13 "1FF00F212"
> As you can see nothing has changed.
> I was wondering which version of PostGIS (and on which platform) has been
> used for producing the material reported into the tutorial (which shows 2
> rows as a correct result).
> I understand that it is difficult to find the reason for different results
> on different platforms but this shouldn't happen otherwise users are
> confused.. and not sure about the correct results.
> When in the near future I will upgrade to PostgreSQL 18 and PostGIS 3.6.0
> I will try again the same two queries and let you know if the results will
> be the same or not.
> Thanks for the time you have spent on this matter.
> Antonio
> Il giorno mer 15 ott 2025 alle ore 22:03 Paul Ramsey <
> On Wed, Oct 15, 2025 at 12:53 PM Antonio Valanzano <anvalanz at gmail.com>
> wrote:
> Hi Paul
> I have upgraded to PosGIS 3.5.3 and GEOS 3.13.1 as you can see from the
> following output
> "postgis_full_version"
> "POSTGIS=""3.5.3 3.5.3"" [EXTENSION] PGSQL=""170""
> GEOS=""3.13.1-CAPI-1.19.2"" PROJ=""8.2.1 NETWORK_ENABLED=OFF URL_ENDPOINT=
> https://cdn.proj.org
> DATABASE_PATH=C:\Program
> Files\PostgreSQL\17\share\contrib\postgis-3.5\proj\proj.db"" (compiled
> against PROJ 8.2.1) LIBXML=""2.12.5"" LIBJSON=""0.12""
> LIBPROTOBUF=""1.2.1"" WAGYU=""0.5.0 (Internal)"" (core procs from ""3.5.2
> 3.5.2"" need upgrade)"
> but the results are the same with one row for a query and 2 rows for the
> other query.
> Is this a known bug or no other user has already reported this behaviour ?
> Not reported, and I'm afraid not solvable unless you can figure out the
> specific thing about your install vs mine that is giving you a different
> answer. (Windows is one possibility, though not one I particularly like,
> platform differences are incredibly hard to isolate.)
> Seeing if the problem is ordering based and number of entries based might
> be interesting.
> DELETE FROM docsk;
> INSERT INTO docks ( geom, good )
> VALUES
> ('LINESTRING (170 290, 205 272)',true),
> ('LINESTRING (120 215, 176 197)',true),
> ('LINESTRING (290 260, 340 250)',false),
> ('LINESTRING (350 300, 400 320)',false),
> ('LINESTRING (370 230, 420 240)',false),
> ('LINESTRING (370 180, 390 160)',false);
> P
> Antonio
> Il giorno mer 15 ott 2025 alle ore 20:59 Paul Ramsey <
> Sorry, I still cannot replicate. My 3.5 build still returns both results.
> Maybe update to PostGIS 3.5.4 and GEOS 3.13.1 ?
> P.
> On Wed, Oct 15, 2025 at 11:25 AM Antonio Valanzano <anvalanz at gmail.com>
> wrote:
> Here is the details of my installation:
> "POSTGIS=""3.5.2 3.5.2"" [EXTENSION] PGSQL=""170""
> GEOS=""3.13.0-CAPI-1.19.0"" PROJ=""8.2.1 NETWORK_ENABLED=OFF URL_ENDPOINT=
> LIBPROTOBUF=""1.2.1"" WAGYU=""0.5.0 (Internal)"""
> Antonio
> Il giorno mer 15 ott 2025 alle ore 19:28 Paul Ramsey <
> Maybe you have found an old bug? Running exactly the same SQL as you, I
> get two rows from each query.
> postgis=# SELECT
> d.id,
> '1FF00F212');
> id | patternmatrix
> 1 | 1FF00F212
> 2 | 1FF00F212
> (2 rows)
> postgis=# SELECT
> postgis-# d.id,
> postgis-# ST_Relate(d.geom, l.geom) as patternMatrix
> postgis-# FROM docks as d, lakes as l
> postgis-# WHERE ST_Relate(d.geom, l.geom) = '1FF00F212';
> id | patternmatrix
> 1 | 1FF00F212
> 2 | 1FF00F212
> (2 rows)
> postgis=#
> postgis=# select postgis_full_version();
> POSTGIS="3.7.0dev 3.6.0rc2-134-g5dc95f1bc" [EXTENSION] PGSQL="180"
> GEOS="3.15.0dev-CAPI-1.21.0" PROJ="9.6.2 NETWORK_ENABLED=ON URL_ENDPOINT=
> USER_WRITABLE_DIRECTORY=/Users/pramsey/Library/Application Support/proj
> DATABASE_PATH=/opt/homebrew/Cellar/proj/9.6.2/share/proj/proj.db" (compiled
> against PROJ 9.6.2) LIBXML="2.9.13" LIBJSON="0.18" LIBPROTOBUF="1.5.2"
> WAGYU="0.5.0 (Internal)" (core procs from "3.7.0dev
> 3.6.0rc2-125-g747d7732b" need upgrade)
> On Wed, Oct 15, 2025 at 9:22 AM Antonio Valanzano <anvalanz at gmail.com>
> wrote:
> I am following the "Introduction to PostGIS " tutorial at
> https://postgis.net/workshops/postgis-intro/
> and for chapter 26 "Dimensionally Extended 9-Intersection Model" I am
> trying to replicate the examples.
> If I use the two different versions of ST_Relate I do not obtain the same
> result
> SELECT
> d.id,
> -- 1 row
> 1 "1FF00F212"
> SELECT
> d.id,
> -- 2 rows
> 1 "1FF00F212"
> 2 "1FF00F212"
> Could someone give me an explanation of such a difference ?
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20251016/c8497b64/attachment.htm>
