Why PostGIS sets a max value for SRID IDs?
G. Allegri
giohappy at gmail.com
Mon Oct 27 02:46:26 PDT 2025
Hello list,
I'm working on two projects where custom CRSs, with custom authorities and
IDs are provided.
Both projects use IDs with numbers beyond SRID_USR_MAX=998999 [1], which is
hardcoded in PostGIS for the spatial_ref_sys id field values.
I can use the auth_id, of course, but having to reassign an id < 998999 is
a bit problematic for two reasons:
- I have custom transformation pipelines defined inside the proj.db, where
the custom IDs are defined for CRSs.
- other softwares (QGIS, Geoserver) can use the custom IDs but they cannot
match the geometries SRIDs returned PostGIS
I wonder if there's a technical reason for the SRID_USR_MAX constant, and
if there's any change to remove it in the future.
And I wonder if others have faced the problems I'm having due to this, and
what are the solutions they came up with.
Thanks,
Giovanni
[1]
https://github.com/postgis/postgis/blob/5dc95f1bc3047b048128616d4543b603b8bbdca7/configure.ac#L1554
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20251027/520a9bcc/attachment.htm>
