Why PostGIS sets a max value for SRID IDs?
Regina Obe
lr at pcorp.us
Mon Oct 27 06:11:54 PDT 2025
I vaguely recall someone complaining about this 15 years ago, but not since then.
Paul can better speak for the reason, but I think it was because we needed to fit it into the header of the geometry and still have enough bits left for the geometry type etc and 2 bits extra for growth.
So I would say it’s very unlikely we’d lift this restriction.
Sent: Monday, October 27, 2025 5:46 AM
To: postgis-users at lists.osgeo.org
Subject: Why PostGIS sets a max value for SRID IDs?
Hello list,
I'm working on two projects where custom CRSs, with custom authorities and IDs are provided.
Both projects use IDs with numbers beyond SRID_USR_MAX=998999 [1], which is hardcoded in PostGIS for the spatial_ref_sys id field values.
I can use the auth_id, of course, but having to reassign an id < 998999 is a bit problematic for two reasons:
- I have custom transformation pipelines defined inside the proj.db, where the custom IDs are defined for CRSs.
- other softwares (QGIS, Geoserver) can use the custom IDs but they cannot match the geometries SRIDs returned PostGIS
I wonder if there's a technical reason for the SRID_USR_MAX constant, and if there's any change to remove it in the future.
And I wonder if others have faced the problems I'm having due to this, and what are the solutions they came up with.
Thanks,
Giovanni
[1] https://github.com/postgis/postgis/blob/5dc95f1bc3047b048128616d4543b603b8bbdca7/configure.ac#L1554
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20251027/4800cc53/attachment.htm>
