Spatial join issues
Greg Troxel
gdt at lexort.com
Wed Oct 29 07:36:43 PDT 2025
Shaozhong SHI <shishaozhong at gmail.com> writes:
> Visually, there appears some matching polygons. Even if two geometries
> represent the same shape visually, they might not be considered equal due
> to tiny differences in precision or metadata. Have you encountered
> problems of failure of spatial join? How did you overcome the problems?
> Regards, David
Could you post your example polygons, and the queries you are using?
Your question is much too open ended. It even sounds like it might be a
request for help with GIS homework, but it's hard to tell :-)
