Wrong SFCGAL version used for compiling PostGIS 3.6.0 on Ubuntu?
Marco Boeringa marco at boeringa.demon.nl
Wed Sep 3 07:08:53 PDT 2025
I noticed 3.6.0 became available on Ubuntu 24.04 where I am currently
running my PostgreSQL / PostGIS install.
However, after adding the 'postgis_sfcgal' extension and the PostGIS
extension upgrades using "SELECT postgis_extensions_upgrade();",
attempting to use the new 'CG_Simplify' function that requires SFCGAL in
as SQL statement, leads to the following error:
"SQL Error [XX000]: ERROR: The SFCGAL version this PostGIS binary was
compiled against (10501) doesn't support 'sfcgal_geometry_simplify'
function (requires SFCGAL 2.1.0+)"
Is this is a possible error during the packaging for the latest release
for Ubuntu?
Marco
