Geometry / geography woes
nikolai.berkoff
nikolai.berkoff at pm.me
Wed Sep 10 06:39:15 PDT 2025
Thank you,
A local coordinate system would not work for us as we are calling ST_Subdivide on the ranges of all species in the IUCN Redlist, so it is very much global problem. I believe ST_Segmentize would solve this for us.
Would you consider a documentation update to ST_Subdivide and the the FAQ warning about this?
For the FAQ something like:
NOTE: If you plan to re-project geometries after using ST_Subdivide(), be aware that the subdivision process may introduce additional vertices. These new vertices do not affect the geometry in the original coordinate system, but they can alter its shape when re-projected — especially if the original vertices span large distances. To mitigate this, consider applying ST_Segmentize() to your geometries before subdivision, ensuring that vertex spacing is appropriate for the target projection or geography-based calculations.
and putting the example Regina gave in https://postgis.net/docs/ST_Subdivide.html ? I would happily make a PR.
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20250910/229a91bf/attachment.sig>
