Dissolve keeping all attributes values (concatenation/aggregation)?
celati Laurent
laurent.celati at gmail.com
Tue Sep 30 07:08:20 PDT 2025
Dear all,
I work with qgis and postgis. I would like to perform a "dissolve":
https://docs.qgis.org/3.40/en/docs/user_manual/processing_algs/qgis/vectorgeometry.html#dissolve
in keeping/preserving all attributes values ? For instance : a kind of
aggregation/concatenation within new "output features" ?
I Saw this post :
https://www.aproposinfosystems.com/en/about/blog/managing-attributes-postgis-dissolve/
<https://www.aproposinfosystems.com/en/about/blog/managing-attributes-postgis-dissolve/>
I have tried to reproduce the proposal with my postgis table containing
several polygons
*SELECT min(union_v4.max_hierar) as id, array_agg(union_v4.id
<http://union_v4.id>) as ids, union_v6.geomFROM union_v4, (SELECT
(ST_Dump(St_multi(ST_Union(geom)))).geom as geom FROM union_v6WHERE
st_intersects(union_v4.geom, union_v6.geom)GROUP BY union_v6.geom*
But i obtain :
*ERROR: syntax error at the end of the entryLINE 12: GROUP BY union_v6.geom
^ERROR: syntax error at the end of the entrySQL state: 42601Characters: 285*
Thanks so much
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20250930/7bcf06a4/attachment.htm>
