Dissolve keeping all attributes values (concatenation/aggregation)?
celati Laurent
laurent.celati at gmail.com
Tue Sep 30 08:29:53 PDT 2025
Dear Erik,
Thank you.
But when i rerun the query with the edit (adding the closing parenthesis) :
*SELECT min(union_v4.max_hierar) as id, array_agg(union_v4.id
<http://union_v4.id>) as ids, union_v6.geomFROM union_v4, (SELECT
(ST_Dump(St_multi(ST_Union(geom)))).geom as geom FROM
union_v6)WHERE st_intersects(union_v4.geom, union_v6.geom)GROUP BY
union_v6.geom*
*I obtain this time the message : * ERROR: la relation « union_v4 »
n'existe pas LINE 5: FROM union_v4, ^ ERREUR: la relation « union_v4 »
n'existe pas SQL state: 42P01 Character: 105
However, i have one table called "union_v4" within my postgis db.
thanks so much.
Le mar. 30 sept. 2025 à 17:04, Erik Wienhold <ewie at ewie.name> a écrit :
> On 2025-09-30 16:08 +0200, celati Laurent wrote:
> > I work with qgis and postgis. I would like to perform a "dissolve":
> https://docs.qgis.org/3.40/en/docs/user_manual/processing_algs/qgis/vectorgeometry.html#dissolve
> > in keeping/preserving all attributes values ? For instance : a kind of
> > aggregation/concatenation within new "output features" ?
> > I Saw this post :
> https://www.aproposinfosystems.com/en/about/blog/managing-attributes-postgis-dissolve/
> > I have tried to reproduce the proposal with my postgis table containing
> > several polygons
> > (ST_Dump(St_multi(ST_Union(geom)))).geom as geom FROM union_v6WHERE
> > st_intersects(union_v4.geom, union_v6.geom)GROUP BY union_v6.geom*
> > But i obtain :
> > *ERROR: syntax error at the end of the entryLINE 12: GROUP BY
> union_v6.geom
> > ^ERROR: syntax error at the end of the entrySQL state: 42601Characters:
> 285*
> Your query is missing the closing parenthesis of the union_v6 subquery
> (after "FROM union_v6"). This should work:
> SELECT
> array_agg(union_v4.id) as ids,
> union_v6.geom
> FROM union_v4,
> (SELECT
> FROM union_v6) union_v6
> GROUP BY union_v6.geom;
> Erik Wienhold
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20250930/dbb0be36/attachment.htm>
