Slowness in testing any crossing straight lines in a layer
Regina Obe
lr at pcorp.us
Thu Feb 5 07:06:19 PST 2026
How many records do you have in a / b
What does this query return and point counts also impact performance
SELECT COUNT(*), MAX(ST_NPoints(geom))
FROM my_fishbones
Also I’d think you’d want to leave out compare with a.id = b.id
I also think the && is redundant as crosses already has a built in index check
SELECT a.*, b.id <http://b.id>
FROM my_fishbones a INNER JOIN my_fishbones b ON (a.id <> b.id AND ST_Crosses(a.geom,b.geom) )
Sent: Thursday, February 5, 2026 7:53 AM
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Subject: Slowness in testing any crossing straight lines in a layer
Hi There!
I have 100K straight lines in a layer - my_fishbone - with GIST indexed. However, the following SQL query did not finish within 20 minutes! Could you advise on any improvement ideas?
FROM my_fishbones a, my_fishbones b
WHERE a.geom && b.geom
AND ST_Crosses(a.geom, b.geom)
Thanks in advance!
Bo Guo
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20260205/7b057789/attachment-0001.htm>
