Slowness in testing any crossing straight lines in a layer
Bo Guo
bo.guo at gisticinc.com
Thu Feb 5 15:03:56 PST 2026
*Versions: *POSTGIS="3.6.1 f533623" [EXTENSION] PGSQL="180"
GEOS="3.10.2-CAPI-1.16.0" PROJ="8.2.1 NETWORK_ENABLED=OFF URL_ENDPOINT=
https://cdn.proj.org USER_WRITABLE_DIRECTORY=/tmp/proj
DATABASE_PATH=/usr/share/proj/proj.db" (compiled against PROJ 8.2.1)
LIBXML="2.9.13" LIBJSON="0.15" LIBPROTOBUF="1.3.3" WAGYU="0.5.0 (Internal)"
(core procs from "3.6.0 4c1967d" need upgrade) TOPOLOGY (topology procs
Yes, this is the Explain Graphics:
[image: image.png]
The Intersects call - SELECT a.*, b.gad_globalid FROM _tmp_fishbone a INNER
JOIN _tmp_fishbone b ON (a.gad_globalid < b.gad_globalid AND
ST_Intersects(a.geom,b.geom) ); took over 15 minutes before pgAdmin session
terminated. I will try it again in a bit.
On Thu, Feb 5, 2026 at 11:38 AM Regina Obe <lr at pcorp.us> wrote:
> What does
> SELECT postgis_full_version();
> Return. I suppose doing a cross join there does result in an order of 6,728,232,002
> checks.
> You definitely have a spatial index on your geometry column right?
> What timing do you get with below, just want to rule out some performance
> issue with ST_Crosses
> FROM _tmp_fishbone a INNER JOIN _tmp_fishbone b ON (a.gad_globalid <
> b.gad_globalid AND ST_Intersects(a.geom,b.geom) );
> *From:* Bo Guo <bo.guo at gisticinc.com>
> *Sent:* Thursday, February 5, 2026 12:59 PM
> *To:* Regina Obe <lr at pcorp.us>
> *Cc:* PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> *Subject:* Re: Slowness in testing any crossing straight lines in a layer
> Hi Regina!
> Your query returned "116002, 2".
> I ran the three variations of the ST_Crosses query, and here are the
> performance results.
> FROM _tmp_fishbone a INNER JOIN _tmp_fishbone b ON (a.gad_globalid <>
> b.gad_globalid AND ST_Crosses(a.geom,b.geom) )
> -- 33 minutes
> -- 17 minutes
> b.gad_globalid AND a.geom && b.geom AND ST_Crosses(a.geom,b.geom) )
> -- 17 minutes
> It seems that 17 mins is the best I can get?
> Thanks!
> On Thu, Feb 5, 2026 at 8:06 AM Regina Obe <lr at pcorp.us> wrote:
> How many records do you have in a / b
> What does this query return and point counts also impact performance
> SELECT COUNT(*), MAX(ST_NPoints(geom))
> FROM my_fishbones
> Also I’d think you’d want to leave out compare with a.id = b.id
> I also think the && is redundant as crosses already has a built in index
> check
> SELECT a.*, b.id
> FROM my_fishbones a INNER JOIN my_fishbones b ON (a.id <> b.id AND
> *Sent:* Thursday, February 5, 2026 7:53 AM
> *To:* PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> *Subject:* Slowness in testing any crossing straight lines in a layer
> Hi There!
> I have 100K straight lines in a layer - my_fishbone - with GIST indexed.
> However, the following SQL query did not finish within 20 minutes! Could
> you advise on any improvement ideas?
> SELECT a.*, b.id
> FROM my_fishbones a, my_fishbones b
> WHERE a.geom && b.geom
> AND ST_Crosses(a.geom, b.geom)
> Thanks in advance!
> Bo Guo
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20260205/855da0ce/attachment.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20260205/855da0ce/attachment.png>
