Coordinate transformations with pipelines
Florian Nadler florian.nadler at cybertec.at
Thu Feb 26 01:29:28 PST 2026
Try projinfo (https://proj.org/en/stable/apps/projinfo.html#examples)
from the commandline of your PostGIS host:
  projinfo -s EPSG:23033 -t EPSG:25833
Transformation can done via  commandline as follows:
cs2cs EPSG:23033 EPSG:25833 <<EOF
541000 4516000
EOF
Florian
Am 24.02.2026 um 08:18 schrieb Antonio Valanzano:
> I am usign PostGIS 3.5 with PostgreSQL 17.0
> Here are the details for my installation:
> "postgis_full_version"
> "POSTGIS=""3.5.3 3.5.3"" [EXTENSION] PGSQL=""170""
> GEOS=""3.13.1-CAPI-1.19.2"" PROJ=""8.2.1 NETWORK_ENABLED=OFF
> URL_ENDPOINT=https://cdn.proj.org
> USER_WRITABLE_DIRECTORY=C:\Windows\ServiceProfiles\NetworkService\AppData\Local/proj
> DATABASE_PATH=C:\Program
> Files\PostgreSQL\17\share\contrib\postgis-3.5\proj\proj.db"" (compiled
> against PROJ 8.2.1)
> LIBXML=""2.12.5"" LIBJSON=""0.12"" LIBPROTOBUF=""1.2.1"" WAGYU=""0.5.0
> (Internal)"" (core procs from ""3.5.2 3.5.2"" need upgrade)"
> I have done the following coordinate transformation
> from  ED50 / UTM zone 33N  (espg:23033)
> to  ETRS89 / UTM zone 33N  (epsg:25833
> SELECT
>   ST_X(ST_Transform(ST_Point(541000,4516000,23033),25833)) as X,
>   ST_Y(ST_Transform(ST_Point(541000,4516000,23033),25833)) as Y;
> -- result
> "x" "y"
> 540998.1383329581 4515921.565374701
> I have read that the best way to utilize PROJ.6 capabilities is by
> allowing the library to freely choose the best possible transformation
> paths
> between the origin and the destination CRSes.
> Does someone know how to find which specific transformation pipeline
> has been chosen by the PROJ.6 library in this specific transformation ?
> Antonio
CYBERTEC PostgreSQL International GmbH
Römerstraße 19, A-2752 Wöllersdorf
Web: https://www.cybertec-postgresql.com
