PostGIS 3.6.1 - ERROR: operator is not unique: public.geometry = public.geometry
Paul Ramsey pramsey at cleverelephant.ca
Thu Jan 8 09:04:49 PST 2026
No, this is clearly a postgres/postgis thing, it doesn't hit on geos or
proj code lines. I was testing with pg18, but I see now Regina has
replicated on pg17 also, so that was the one thing I was working on
clarifying in terms of reproduction.
P
On Thu, Jan 8, 2026 at 8:54 AM Arthur Bazin <arthurbazin at gmail.com> wrote:
> @paul, you have not the exact same version of PostGIS and therefore of
> GEOS and PROJ.
> Maybe the origin of the non reproductibility ?
> Best regards
> Arthur
> Le jeu. 8 janv. 2026, 17:26, Paul Ramsey via postgis-users <
> postgis-users at lists.osgeo.org> a écrit :
>> This is odd, I am not able to replicate...
>>  POSTGIS="3.6.1dev 3.6.0-6-gdb18a9a49" PGSQL="180"
>> GEOS="3.15.0dev-CAPI-1.21.0" PROJ="9.3.0 NETWORK_ENABLED=ON URL_ENDPOINT=
>> https://cdn.proj.org
>> USER_WRITABLE_DIRECTORY=/Users/pramsey/Library/Application Support/proj
>> DATABASE_PATH=/usr/local/share/proj/proj.db" (compiled against PROJ 9.3.0)
>> LIBXML="2.9.13" LIBJSON="0.17" LIBPROTOBUF="1.4.1" WAGYU="0.5.0 (Internal)"
>> (1 row)
>> postgis_reg=# SELECT 'POINT EMPTY'::public.geometry = 'POINT
>> EMPTY'::public.geometry;
>>  ?column?
>>  t
>> (1 row)
>> Is this a database that has gone through upgrade stages, or a blank fresh
>> database?
>> P
>> On Thu, Jan 8, 2026 at 8:21 AM Cedric Duprez <cedric.duprez at ign.fr>
>> wrote:
>>> Hi all,
>>> I'm facing a potential bug with PostGIS 3.6.1 on PostgreSQL 17.7.
>>> Here is what I get with postgis_full_version() :  POSTGIS="3.6.1
>>> f533623" [EXTENSION] PGSQL="170" GEOS="3.12.1-CAPI-1.18.1" PROJ="9.4.0
>>> NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
>>> USER_WRITABLE_DIRECTORY=/tmp/proj DATABASE_PATH=/usr/share/proj/proj.db"
>>> (compiled against PROJ 9.4.0) GDAL="GDAL 3.8.4, released 2024/02/08"
>>> LIBXML="2.9.14" LIBJSON="0.17" LIBPROTOBUF="1.4.1" WAGYU="0.5.0 (Internal)"
>>> RASTER
>>> When I execute this query:
>>> SELECT 'POINT EMPTY'::public.geometry = 'POINT EMPTY'::public.geometry;
>>> I get the following error:
>>> It seems to be a regression, since I didn't have this error on previous
>>> versions of PostGIS (3.5).
>>> How can this problem be solved?
>>> Thanks in advance for you help,
>>> Cedric
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20260108/4043acdc/attachment.htm>
