RE: Inquiry on planned PostGIS releases and minor-version behavior (now–Feb 28)
Regina Obe lr at pcorp.us
Wed Jan 21 11:56:03 PST 2026
As Paul mentioned, we don’t have tentative date plans.   We release when we feel there are enough bug fixes in the list to make it worthwhile or if enough time has passed.
At the moment we generally don’t make a decision to release until about a week before we release.
Not sure what you mean by GEOS/PROJ changes.  Those are separate projects from PostGIS.  PostGIS just relies on them.
From: Bharath Tadikonda <tadikondabharath at gmail.com>
Sent: Wednesday, January 21, 2026 2:38 PM
To: Regina Obe <lr at pcorp.us>
Cc: postgis-users at lists.osgeo.org
Subject: Re: Inquiry on planned PostGIS releases and minor-version behavior (now–Feb 28)
Hi Regina,
"and yes we most likely will do a micro release before February 28"
Could you please let us know if there is a tentative date planned for this micro release? Additionally, will this release include any changes to GEOS or PROJ?
On Wed, Jan 21, 2026 at 2:09 PM Regina Obe <lr at pcorp.us <mailto:lr at pcorp.us> > wrote:
Bharath,
The best advice I can give is to look at the upcoming NEWS items
https://gitea.osgeo.org/postgis/postgis/src/branch/stable-3.6/NEWS
From: Bharath Tadikonda <tadikondabharath at gmail.com <mailto:tadikondabharath at gmail.com> >
Sent: Wednesday, January 21, 2026 1:36 PM
To: postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
Subject: Inquiry on planned PostGIS releases and minor-version behavior (now–Feb 28)
Hello PostGIS Team,
I’m a PostgreSQL Database Engineer managing production PostgreSQL/PostGIS workloads on AWS RDS/Aurora.
We are planning a PostgreSQL minor upgrade (PostgreSQL 16.6 → 16.11) in the near term. In our environment, past PostGIS minor/patch releases have occasionally caused operational issues due to changes in function behavior, even when PostgreSQL itself was a minor upgrade. Because AWS may bundle a newer PostGIS minor version along with a PostgreSQL minor upgrade, we want to plan and execute testing and production rollout as close together as possible.
To help us plan safely, I wanted to ask:
1.	Are there any planned PostGIS releases (minor or patch) between now and February 28?
*	If yes, which versions are anticipated?
*	If not, when is the next postgis version release anticipated?
2.	For PostGIS minor/patch releases (e.g., 3.6.x → 3.6.y):
*	Are changes strictly bug fixes, or can they include behavioral changes to existing functions?
*	Are there specific classes of functions (geometry processing, topology, raster, etc.) where behavior changes are more likely?
3.	Release notes & compatibility guidance:
*	Is there a recommended way to identify function-level behavior changes between minor versions (beyond high-level release notes)?
*	Are there guarantees or best-practice guidance around backward compatibility expectations for PostGIS patch releases?
4.	Operational best practices:
*	Do you recommend pinning PostGIS patch versions in production where possible, or validating only specific functions we rely on most during upgrades?
Any guidance you can share will help us reduce risk and plan upgrades more confidently.
Thank you for your time and for all the work you do on PostGIS.
Best regards,
Bharath
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20260121/1a7009cb/attachment.htm>
