When did this 'officially' change? "SQL-MM defines the default SRID of all geometry constructors as 0. PostGIS uses a default SRID of -1."
Michael Downey mdowney at esri.com
Fri Jan 30 11:52:55 PST 2026
Thank you!
Sent: Friday, January 30, 2026 11:42 AM
To: Michael Downey <mdowney at esri.com>
Cc: postgis-users at lists.osgeo.org
Subject: Re: When did this 'officially' change? "SQL-MM defines the default SRID of all geometry constructors as 0. PostGIS uses a default SRID of -1."
That phrase is no longer in the doco, looks like it got fixed after 3.2 release.
On Fri, Jan 30, 2026 at 11:39 AM Michael Downey <mdowney at esri.com<mailto:mdowney at esri.com>> wrote:
Thanks!
From: Paul Ramsey <pramsey at cleverelephant.ca<mailto:pramsey at cleverelephant.ca>>
Sent: Friday, January 30, 2026 11:38 AM
To: Michael Downey <mdowney at esri.com<mailto:mdowney at esri.com>>
Cc: postgis-users at lists.osgeo.org<mailto:postgis-users at lists.osgeo.org>
PostGIS 2.0? 14 years ago
https://github.com/postgis/postgis/blob/master/NEWS#L1937 [github.com]<https://urldefense.com/v3/__https:/github.com/postgis/postgis/blob/master/NEWS*L1937__;Iw!!CKZwjTOV!3yYvUnUVO6JZpb3quhgJNZvGxIrrJ-8WLx1ZqGThN6rLytjb8XDhluBJKpOw_nLJxA8tmDouYe0kH_nLz0NQQA$>
Wheeps, that's a long-time doo error.
P.
On Fri, Jan 30, 2026 at 11:31 AM Michael Downey via postgis-users <postgis-users at lists.osgeo.org<mailto:postgis-users at lists.osgeo.org>> wrote:
Hello,
I see this note
“SQL-MM defines the default SRID of all geometry constructors as 0. PostGIS uses a default SRID of -1" on the PostGIS_Special_Functions_Index.html page all the way though 3.2
https://postgis.net/docs/manual-3.2/PostGIS_Special_Functions_Index.html [postgis.net]<https://urldefense.com/v3/__https:/postgis.net/docs/manual-3.2/PostGIS_Special_Functions_Index.html__;!!CKZwjTOV!3yYvUnUVO6JZpb3quhgJNZvGxIrrJ-8WLx1ZqGThN6rLytjb8XDhluBJKpOw_nLJxA8tmDouYe0kH_kQKNXXQA$>
Since then it is not there.
I have not checked this question under versions < 3.4. AI results indicate that it was 3.0 when it started. A question from a user in our community indicates 2.0.
Perhaps it started at an earlier time and culminated at 3.3?
Thanks,
Michael
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20260130/29ef6c6c/attachment.htm>
