Slower queries on geometry_columns on 3.7.0beta1
Paragon Corporation lr at pcorp.us
Fri Jul 31 19:25:44 PDT 2026
I have the issue ticketed here -
https://trac.osgeo.org/postgis/ticket/6110  though I think it might
only affect constraint based tables.
Can you try this change, just add a AS NOT MATERIALIZED to the CTE at the top.
As detailed here --
https://trac.osgeo.org/postgis/changeset/9f52dd2f9eeb30f7bc5f774eefe280020f320c52/git
On Thu, Jul 30, 2026 at 7:24 AM Fredrik Widlert
<fredrik.widlert at digpro.se> wrote:
> Hi, I tested postgis-3.7.0beta1 today on PostgreSQL 19 beta 2.
> It appears that selects on geometry_columns has become much slower in my small test database:
> select count(*) from geometry_columns;
> now takes more than two minutes. The SQL from the 3.6.0 version of the view takes a few milliseconds to run.
> I notice that the view is much more complicated in 3.7.0beta1 than what it was in earlier versions,
> so I guess the change is related to the new PostGIS rather than the new PostgreSQL.
> Query plan for the new version here:
> https://explain.depesz.com/s/rtSg
> Is this a known problem? I had Codex build a test case that seems to reproduce something similar
> in an empty database, but I'm not sure if it shows exactly the same problem I'm encountering.
> Anyway, this test case is included below in case it is useful.
> On my machine, the testcase shows the 3.6 version taking 2 millis and the 3.7 version 11 seconds.
> /Fredrik Widlert
> \set ON_ERROR_STOP on
> \timing on
>  * Reproducer for slow geometry_columns queries with the PostGIS 3.7
>  * definition.
>  * Run this with psql as a superuser in a new, otherwise empty database.
>  * The test deliberately creates many CHECK constraints which have nothing to
>  * do with PostGIS.  The 3.7 geometry_columns definition builds constraint_defs
>  * from every row in pg_constraint, calls pg_get_constraintdef() for each row,
>  * and scans the result three times with regular expressions.  Consequently,
>  * unrelated constraints affect the time needed to inspect geometry columns.
>  * A partitioned table is used to populate pg_constraint without needing
>  * thousands of CREATE TABLE statements: its 100 CHECK constraints are copied
>  * to each of 200 partitions, producing about 20,000 unrelated
>  * pg_constraint rows.
>  * The spatial tables use constraint-based geometry columns rather than
>  * typmods.  This is important because it exercises the constraint inference
>  * added to geometry_columns in 3.7.  Views over those tables also exercise
>  * _postgis_geometry_columns_view_column_origin().
>  * On slower machines, lower the loop upper bounds below.  The product of the
>  * CHECK-constraint and partition counts controls most of the catalog load.
> CREATE EXTENSION postgis;
> DO $roles$
> BEGIN
> IF NOT EXISTS (
> SELECT
> FROM pg_catalog.pg_roles
> WHERE rolname = 'slow_columns_reader'
> ) THEN
> CREATE ROLE slow_columns_reader NOLOGIN;
> END IF;
> IF NOT EXISTS (
> SELECT
> WHERE rolname = 'slow_columns_user'
> ) THEN
> CREATE ROLE slow_columns_user NOLOGIN;
> END IF;
> END
> $roles$;
> GRANT slow_columns_reader TO slow_columns_user;
> CREATE SCHEMA slow_columns_repro;
>  * Create the unrelated catalog load first.  Constraints are added to the
>  * parent before its partitions are created so PostgreSQL copies them into
>  * every partition.
> CREATE TABLE slow_columns_repro.constraint_noise (
> id integer NOT NULL
> ) PARTITION BY RANGE (id);
> DO $noise$
> BEGIN
> FOR i IN 1..100 LOOP
> EXECUTE format(
> 'ALTER TABLE slow_columns_repro.constraint_noise '
> 'ADD CONSTRAINT %I CHECK (id >= %s)',
> 'noise_check_' || i,
> -i
> END LOOP;
> FOR i IN 0..199 LOOP
> EXECUTE format(
> 'CREATE TABLE slow_columns_repro.%I '
> 'PARTITION OF slow_columns_repro.constraint_noise '
> 'FOR VALUES FROM (%s) TO (%s)',
> 'constraint_noise_' || i,
> i,
> i + 1
> END LOOP;
> END
> $noise$;
>  * AddGeometryColumn(..., use_typmod => false) creates legacy CHECK
>  * constraints for dimensionality, SRID, and geometry type.  The example in
>  * slow_columns.sql used typmods and therefore did not exercise this path.
> DO $spatial_objects$
> DECLARE
> table_name text;
> view_name text;
> BEGIN
> table_name := 't' || i;
> view_name := 'v' || i;
> EXECUTE format(
> 'CREATE TABLE slow_columns_repro.%I (id bigint)',
> table_name
> PERFORM AddGeometryColumn(
> 'slow_columns_repro',
> table_name,
> 'shape',
> 5845,
> 'POINT',
> 3,
> false
> EXECUTE format(
> 'CREATE VIEW slow_columns_repro.%I AS '
> 'SELECT id, shape FROM slow_columns_repro.%I',
> view_name,
> table_name
> END LOOP;
> END
> $spatial_objects$;
> GRANT USAGE ON SCHEMA slow_columns_repro TO slow_columns_reader;
> GRANT SELECT ON ALL TABLES IN SCHEMA slow_columns_repro
>  * Preserve the 3.6 definition under another name so both versions see the
>  * exact same catalog and privileges.
> CREATE VIEW slow_columns_repro.geometry_columns_36 AS
> SELECT
> current_database()::varchar(256) AS f_table_catalog,
> n.nspname AS f_table_schema,
> c.relname AS f_table_name,
> a.attname AS f_geometry_column,
> COALESCE(postgis_typmod_dims(a.atttypmod), 2) AS coord_dimension,
> COALESCE(NULLIF(postgis_typmod_srid(a.atttypmod), 0), 0) AS srid,
> replace(
> replace(
> COALESCE(
> NULLIF(upper(postgis_typmod_type(a.atttypmod)), 'GEOMETRY'),
> 'GEOMETRY'
> 'ZM',
> 'Z',
> )::varchar(30) AS type
> FROM pg_catalog.pg_class AS c
> JOIN pg_catalog.pg_attribute AS a
> ON a.attrelid = c.oid
> AND NOT a.attisdropped
> JOIN pg_catalog.pg_namespace AS n
> ON c.relnamespace = n.oid
> JOIN pg_catalog.pg_type AS t
> ON a.atttypid = t.oid
> WHERE c.relkind = ANY (ARRAY['r'::"char", 'v'::"char", 'm'::"char",
> 'f'::"char", 'p'::"char"])
> AND c.relname <> 'raster_columns'
> AND t.typname = 'geometry'
> AND NOT pg_catalog.pg_is_other_temp_schema(c.relnamespace)
> AND pg_catalog.has_table_privilege(c.oid, 'SELECT');
> GRANT SELECT ON slow_columns_repro.geometry_columns_36
>  * Give the planner current catalog statistics.  Without this, results can
>  * depend on whether autovacuum happened to run during fixture creation.
> ANALYZE pg_catalog.pg_class;
> ANALYZE pg_catalog.pg_attribute;
> ANALYZE pg_catalog.pg_constraint;
> ANALYZE pg_catalog.pg_namespace;
> ANALYZE pg_catalog.pg_rewrite;
> ANALYZE pg_catalog.pg_type;
> SET ROLE slow_columns_user;
> SET jit = off;
> \echo
> \echo 'Catalog size used by the reproducer:'
> SELECT count(*) AS constraint_count
> FROM pg_catalog.pg_constraint;
> \echo
> \echo 'PostGIS 3.6 geometry_columns definition (baseline):'
> EXPLAIN (ANALYZE, BUFFERS, TIMING OFF, SUMMARY ON)
> SELECT count(*)
> FROM slow_columns_repro.geometry_columns_36
> WHERE f_table_schema = 'slow_columns_repro';
> \echo
> \echo 'Installed PostGIS geometry_columns definition (3.7 regression):'
> SELECT count(*)
> FROM public.geometry_columns
> RESET ROLE;
