Coordinate transformations with pipelines
Florian Nadler florian.nadler at cybertec.at
Mon Jun 1 23:36:26 PDT 2026
Dear Antonio,
sorry for being late, I took a deeper look at the operatios output.
I believe the reason why Proj did not choose Operation 1/2 as winner is
the related extent (stored in the extent table in proj.db), which does
not cover your coordinate.
To cross-check I adopted the extent in proj.db and executed your command
again from the command line:
cs2cs EPSG:23033 EPSG:25833
                             541000 4516000
540931.34       4515810.60 0.00
Cheers, Florian
Am 26.02.2026 um 11:28 schrieb Antonio Valanzano:
> 541000 4516000
CYBERTEC PostgreSQL International GmbH
Römerstraße 19, A-2752 Wöllersdorf
Web: https://www.cybertec-postgresql.com
