Possible Bug in postgis_restore
Sandro Santilli
strk at kbt.io
Fri Mar 27 15:45:47 PDT 2026
This is a big, could you please file it on https://trac.osgeo.org/postgis ?
Il 26 marzo 2026 09:17:32 CET, "Aussem, Robert (LGL extern) via postgis-users" <postgis-users at lists.osgeo.org> ha scritto:
>Hello,
>during a Migration from postgis 3.1 to 3.5 using the Script postgis_restore i found a strange behaviour:
>In our Database we had a Table named layer in a Schema that didn't belong to postgis. After the run of postgis_restore the Table didn't exist and
>the Import had errors when it tried load Data in this Table. In a verbose run i saw this:
>SKIP: TABLE layer
>Here postgis_restore seemed to ignore the Schema.
>Is it common practice not to use Tables named layer in a postgis enabled database or could this be a Bug?
>Yours sincerely
>Robert Aussem
Sent from hand-held device with K-9 Mail. Please excuse my brevity.
