longer EPSG WKT2
Regina Obe
lr at pcorp.us
Wed Sep 9 07:42:00 PDT 2026
> EPSG now has an ensemble for ETRS89 and those have many members, e.g.
> https://epsg.org/crs/wkt/id/25830
> which are well beyond the 2048 size in the table definition.
> I therefore wonder:
> What version of the EPSG database does postgis come with (seems hard
> to find in NEWS?)?
> What is the relationship between the postgis EPSG version and the proj
> EPSG version?
> Should the table fields become larger? Perhaps 16384?
> and
> If postgis depends on proj, why isn't it just using the EPSG database
> from proj?
> (This issue was raised by Javier on the proj list.)
It is mostly just using the proj.db. Anything beyond storage of srid and
auth_srid is considered legacy use in PostGIS.
PostGIS always checks proj.db for core definitions if the auth_srid exists
in the proj.db. The srtext / proj4text is only used of the definitions don't
exist in proj.db.
We've had this debate for a while if PostGIS should just come with an
essentially empty spatial_ref_sys and as part of user responsibility load
what they need to load
from proj.db and even making spatial_ref_sys a view that just wraps a
function that reads from proj.db. That would largely solve the issue with
have with pg_upgrade that in some cases tables are loaded before
spatial_ref_sys is populated.
There was discussion that editing the proj.db is harder to edit than the
spatial_ref_sys for users wanting to define their own custom projection, so
that was the big boo against getting rid of spatial_ref_sys as a table.
Other reason is it would probably kill performance.
