[OSRS-PROJ] projUV / UV
Gerald I. Evenden gevenden at capecod.net
Wed Apr 26 07:43:13 PDT 2000
You catch me at a bad time as I am about to upgrade my system
and do a lot of moving and backup so my source of PROJ is
in current limbo.  But, ...
I realize that defines used in one system may be inconflict with other,
totally unrelated, systems but I question the desirablility of the method
to resolve this problem, especially one that requires changes to basic
elements of either system.  BTW, when referring to "windows" are we
talking M$ or X11?
A second point is release number and basic designation of PROJ.4.
This brings up the point as to the "official" source point of PROJ.4.
In some cases, this is view as the USGS site kai.er.usgs.gov.
It is going to get *very* confusing if different sites come up with
individual audit trails on their release numbers for the basic
designation of "PROJ.4."
This is not supplying solutions, just raising some issues.
Jerry Evenden and the low riders: Katie and Daisy-Mae
gevenden at capecod.net  http://www.capecod.net/~gevenden
-----Original Message-----
To: osrs-proj at remotesensing.org <osrs-proj at remotesensing.org>
Date: Wednesday, April 26, 2000 9:15 AM
Subject: [OSRS-PROJ] projUV / UV
>Folks,
>One of the changes to PROJ requested for Windows portability was to rename
>UV as it conflicted with some windows define.  I modified the structure
name
>to projUV in all the PROJ.4 code in the 4.4.0/1 releases.  However, I
didn't
>really think it through very carefully, and as released there is no way for
>a program being built to detect whether it should use UV or projUV.  I have
>modified projects.h to #define USE_PROJUV in newer versions so that
applications
>can check for this.  Unfortunately PROJ 4.4.0 and 4.4.1 will still be hard
to
>identify.  For anyone in a pinch it should be sufficient to #define projUV
to
>UV before #including projects.h if USE_PROJUV isn't used.
>Best regards,
OSRS PRoject PROJ Discussion List
To Subscribe: send a message to majordomo at remotesensing.org with 'subscribe osrs-proj' in the body
To Unsubscribe: send a message to majordomo at remotesensing.org with 'unsubscribe osrs-proj' in the body
To Report Problems: send a message to owner-osrs-proj at remotesensing.org
