[OSRS-PROJ] Datum Shifting
Morten Hulden
morten at ngb.se
Tue Jul 4 08:21:38 PDT 2000
On Tue, 4 Jul 2000, Frank Warmerdam wrote:
> We also need a way of driving coordinate system to coordinate system conversion
> from the command line. I torn between extending the ``proj'' command with
> some methodology of defining a second coordinate system, or implement a new
> command which operates coordinate system to coordinate system. Perhaps a
> proj2proj command or something like that. I am open to suggestions on this.
Isn't +proj=ob_tran already doing something similar (rotating from one
projection to another). Could the existing code be used or extended to
cover your changes?
Morten Hulden
Nordic Gene Bank
OSRS PRoject PROJ Discussion List
To Subscribe: send a message to majordomo at remotesensing.org with 'subscribe osrs-proj' in the body
To Unsubscribe: send a message to majordomo at remotesensing.org with 'unsubscribe osrs-proj' in the body
To Report Problems: send a message to owner-osrs-proj at remotesensing.org
More information about the Proj
