[OSRS-PROJ] Datum Shifting
    Morten Hulden
    morten at ngb.se
    Tue Jul  4 09:04:55 PDT 2000
Frank,
On Tue, 4 Jul 2000, Frank Warmerdam wrote:
> As I understand it the current ``proj'' command only allows conversion between
> a single projected coordinate system and geodetic (lat/long) coordinates on
> the same ellipsoid.  In particular, there is no way to convert directly from
> one projection to another since it is assume that all projection definition
> information on the commandline relates to one definition.
ob_trans projection allows a second projection to be specified e.g. (a
pole shift)
proj +ellps=clrk66 proj=ob_trans +lon_0=20 +o_proj=tmerc o_lon_p=45
but, you are correct, not a second ellipsoid
and anyway I think your approach is cleaner:
> proj +proj=utm +zone=11 +ellps=clrk80 -to +proj=utm +zone=11 +ellpse=GRS80
Morten Hulden
OSRS PRoject PROJ Discussion List
To Subscribe: send a message to majordomo at remotesensing.org with 'subscribe osrs-proj' in the body
To Unsubscribe: send a message to majordomo at remotesensing.org with 'unsubscribe osrs-proj' in the body
To Report Problems: send a message to owner-osrs-proj at remotesensing.org
More information about the Proj
