[OSRS-PROJ] ArcView projection & PROJ.4 projection
Frank Warmerdam
warmerda at home.com
Wed Jul 19 07:14:18 PDT 2000
kibez wrote:
> I had problem with installation necessary projection for a map
> In ArcView it is described so:
> Projection: Transverse Mercator
> Spheroid: Krasovsky
> Central Meridian: 33.0
> Reference Latitude: 0.0
> Scale Factor: 1.0
> False Easting: 6500.0
> False Northing: 0.0
> It is possible - whether to describe such projection a mapserver ???
> (PROJ.4 ???)
> PROJECTION
> "PROJ = tmerk"
> "ELLPS = krass"
I must confess I am not clear on MapServer syntax for using PROJ.4; however,
the PROJ.4 parameters would be:
proj=tmerc lon_0=33.0 lat_0=0.0 k_0=1.0 x_0=6500.0 y_0=0.0 ellps=krass
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam, warmerda at home.com
light and sound - activate the windows | http://members.home.com/warmerda
and watch the world go round - Rush | Geospatial Programmer for Rent
OSRS PRoject PROJ Discussion List
To Subscribe: send a message to majordomo at remotesensing.org with 'subscribe osrs-proj' in the body
To Unsubscribe: send a message to majordomo at remotesensing.org with 'unsubscribe osrs-proj' in the body
To Report Problems: send a message to owner-osrs-proj at remotesensing.org
More information about the Proj
