[OSRS-PROJ] gauss-krueger/transverse mercator
Markus Neteler
neteler at geog.uni-hannover.de
Mon Jun 12 13:40:17 PDT 2000
Hi Andreas,
maybe not an answer for your question, but of general
(European) interest: I convert with following calls:
Rechtswert Hochwert -> Lat Long
proj -I +proj=tmerc +a=6377397.1550000003 +es=0.0066743720\
+lat_0=0.0000000000 +lon_0=$bezug +k=1.0000000000 +x_0=$ans +unfact=1.0000000000
where $bezug=meridian (degree, example: 9)
and $ans= False Easting (example: 3500000)
Example:
In: 3560000 5700000
Out: 9d51'46.414"E 51d25'57.97"N
Reverse transformation:
Lat Long -> Hochwert Rechtswert (y x)
proj +proj=tmerc +a=6377397.1550000003 +es=0.0066743720 +lat_0=0.0000000000\
Example:
In: 9d51'46.414"E 51d25'57.97"N
Out: 3560000.01 5699999.99
Using your example I get (note: reverse order):
10.5W 29.27N
1585979.82 3402162.10
I am not shure if it is defined in southern hemisphere (but why
not, at least numerically)?
Best wishes
Markus
On Mon, Jun 12, 2000 at 01:43:19PM +0200, Andreas Lange wrote:
> Hi,
> i have a problem with the transverse mercator projection (Gauss-Kruger
> Projection) only indirectly connected to proj4.
> I am writing a program for data exchange with garmin gps receivers,
> which give the position always in lat/lon wgs84, even if the receiver
> itself displays position and waypoints in 'german grid' coordinates
> (transverse mercator projection). I know that german grid here for
> germany uses 3 degree wide meridian stripes (0d, 3d E, 6d E etc.), adds
> a false easting of 500000 and prefixes the zone (0, 1, 2, 3, etc).
> But what on the southern hemisphere? Is there a constant false northing
> of 10000 m added as with UTM? The receiver displays only "----", so that
> i assume it is not defined for southern hemisphere.
> What with western longitudes? What with two-digit zones?
> The receiver gives me the following readings:
> lat lon easting/northing
> 29.27N 10.5W 5436500/5815100 (??)
> 29.27N 10.5E 4354200/3240000 (ok)
> 29.27N 18.83E 5579200/1675000 (??)
> 29.27N 18.83W 5923300/9718000 (??)
> 85.44N 18.83E 5009100/0035000 (??)
> 85.44N 18.83W 5923000/9718000 (??)
> Are those values (??) only an internal overflow of the receiver?
> Thank you in advance for any hints,
> Andreas Lange
> Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
> Andreas.Lange at Rhein-Main.de, A.C.Lange at GMX.net
OSRS PRoject PROJ Discussion List
To Subscribe: send a message to majordomo at remotesensing.org with 'subscribe osrs-proj' in the body
To Unsubscribe: send a message to majordomo at remotesensing.org with 'unsubscribe osrs-proj' in the body
To Report Problems: send a message to owner-osrs-proj at remotesensing.org
More information about the Proj
