[OSRS-PROJ] C++ friendly header file?
Frank Warmerdam
warmerda at home.com
Thu Mar 30 10:11:17 PST 2000
Rick Brownrigg wrote:
> I've used this library for years, and its great to see renewed interest
> in it.
> As I typically use C++, I've found that I have problems linking my
> code. My quick-N-dirty solution is to patch the "projects.h" header
> file, surround everything by
> #ifdef __cplusplus
> #extern "C" {
> endif
> #ifdef __cplusplus
> #endif
> directives. This is easy enough to do, but I inevitably forget for new
> installations. There may also be a cleaner approach, and I admit I
> haven't investigated thoroughly.
> Anyone else see this? Have better solutions? More to the point, could
> we get whatever prefered solution incorporated into the next release?
Rick,
Excellent idea. I have applied this to projects.h and geodesic.h in CVS.
This is the standard way I handle C linkage header files I want to be compatible
with C++.
Note that it's "extern "C" {" not "#extern "C" {".
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam, warmerda at home.com
light and sound - activate the windows | http://members.home.com/warmerda
and watch the world go round - Rush | Geospatial Programmer for Rent
OSRS PRoject PROJ Discussion List
To Subscribe: send a message to majordomo at remotesensing.org with 'subscribe osrs-proj' in the body
To Unsubscribe: send a message to majordomo at remotesensing.org with 'unsubscribe osrs-proj' in the body
To Report Problems: send a message to owner-osrs-proj at remotesensing.org
More information about the Proj
