[OSRS-PROJ] datum shift
Andreas Lange Andreas.Lange at Rhein-Main.de
Wed May 24 09:44:42 PDT 2000
i have some questions relating to the different datum shift formulae.
I would be glad if someone could give me an answer or a pointer for the
world wide web.
What is the difference between the Bursa-Wolf transformation and the
(3d) similarity transformation? On some web-pages theses terms are used
interchangebly, others imply that there are different
formula/parameters.
What is the difference between the Molodensky transformation and the
"abridged Molodensky" transformation. I only found the description of
the Molodensky transformation on Peter H. Dana's excellent webpages
(http://www.utexas.edu/depts/grg/gcraft/notes/datum).
Thanks a lot in advance,
Andreas
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange at Rhein-Main.de, A.C.Lange at GMX.net
OSRS PRoject PROJ Discussion List
To Subscribe: send a message to majordomo at remotesensing.org with 'subscribe osrs-proj' in the body
To Unsubscribe: send a message to majordomo at remotesensing.org with 'unsubscribe osrs-proj' in the body
To Report Problems: send a message to owner-osrs-proj at remotesensing.org
