[OSRS-PROJ] WGS84/GEODETIC Projection
Frank Warmerdam
warmerdam at pobox.com
Wed Nov 22 12:47:24 PST 2000
Brian Hall wrote:
> Hello,
> Can PROJ.4 do the WGS84/GEODETIC projection? If so, what is the init
> string?
Brian,
The proj command translates between projection coordinates (in a defined
projection), and geodetic coordinates in the same datum/ellipsoid. So
what are you wanting to translate to/from WGS84/Geodetic?
If you need to do datum shifting there is experimental support for that
in the new cs2cs program. Let me know if that's what you need.
Best regards,
light and sound - activate the windows | http://pobox.com/~warmerda
and watch the world go round - Rush | Geospatial Programmer for Rent
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
More information about the Proj
