[OSRS-PROJ] Support for Transverse Mercator south-oriented projection.
Gerald I. Evenden gevenden at capecod.net
Wed Sep 20 08:04:42 PDT 2000
Without my having to dig out my references out, is the sign of the northing
increase
in a positive manner as the latitude increases southerly?
Logical use of TM would dictate that the normal TM projection is used with a
false northing sufficiently far south to make the "zone" of interest still
positive in
the northing values.  To do otherwise is most illogical, to say the least.
Also: "westing?"  Is that positive also?
My, my, I'm getting the idea that being "down under" has drained all the
blood from the head to the other end.  But the Ausies don't seem to have
this problem.
______________
Jerry Evenden and the Low Riders, Katie and  Daisy May
gevenden at capecod.net  http://www.capecod.net/~gevenden
----- Original Message -----
To: <osrs-proj at remotesensing.org>
Sent: Wednesday, September 20, 2000 11:26 AM
Subject: Re: [OSRS-PROJ] Support for Transverse Mercator south-oriented
projection.
> "Gerald I. Evenden" wrote:
> > What do you mean "south oriented projection?"
> Jerry,
> See the description extracted from the EPSG database:
http://www.remotesensing.org/geotiff/proj_list/transverse_mercator_south_ori
ented.html
> Assuming this isn't directly supported now, how would you suggest handling
> it within PROJ.4?  Should a new proj=tmso be implemented that just
internally
> calls the proj=tm code, and transforms the coordinates appropriately
> afterwards?
OSRS PRoject PROJ Discussion List
To Subscribe: send a message to majordomo at remotesensing.org with 'subscribe osrs-proj' in the body
To Unsubscribe: send a message to majordomo at remotesensing.org with 'unsubscribe osrs-proj' in the body
To Report Problems: send a message to owner-osrs-proj at remotesensing.org
