[OSRS-PROJ] PROJ-4.4.2 Release
Frank Warmerdam
warmerda at home.com
Fri Sep 22 10:12:11 PDT 2000
Folks,
I am issuing a PROJ 4.4.2 release. It includes the new datum handling, which
should be considered an "Alpha" release, but in other regards it should be a
stable production release.
It can be downloaded from:
ftp://ftp.remotesensing.org/pub/proj/proj-4.4.2.tar.gz
ftp://ftp.remotesensing.org/pub/proj/proj-4.4.2.zip
The ChangeLog reports:
-- 2000-09-22 Frank Warmerdam <warmerda at cs46980-c>
* Update version to 4.4.2, in preparation for 4.4.2 release.
* Ensure makefile.vc is distributed, and mention windows building
in README.
* Cast args to freev2() in bch2bps.c, and mk_cheby.c to avoid errors
on the Cray.
2000-09-21 Frank Warmerdam <warmerda at cs46980-c>
* Added "sphere" to pj_ellps.c.
2000-07-06 Frank Warmerdam <warmerda at cs46980-c>
* Fixed bug in nad_init() with path for datum shifting files.
* Implemented cs2cs program for transforming between coordinate systems
including datum shifts.
* Implemented proj=latlong pseudo-projection.
* Implemented pj_transform() to transform from one coordinate system
to another, including applying geocentric datum shifts, and NAD27
grid shifts.
* Implemented 3/7 parameter geocentric datum shift support.
* Added support for +datum, +towgs84, and +nadgrids parameters
when defining PJ's (for pj_init()). Added datum_type, and datum_params
to PJ structure.
2000-07-04 Frank Warmerdam <warmerda at cs46980-c>
* Patched proj.c to handle binary io properly on Windows and DOS.
Patch submitted by Thomas Knudsen <thk at kms.dk>.
2000-04-26 Frank Warmerdam <warmerda at cs46980-c>
* Added #define USE_PROJUV to projects.h to allow apps to
work properly against old and new version.
2000-04-04 Frank Warmerdam <warmerda at rommel.atlsci.com>
* Patch from Craig Bruce (cbruce at cubewerx.com) for PJ_ortho.c
to make INVERSE() work well for points near zero.
2000-03-29 Frank Warmerdam <warmerda at cs46980-c>
* Added hard links for invproj->proj and invgeod->geod in
src/Makefile.{am,in}.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam, warmerda at home.com
light and sound - activate the windows | http://members.home.com/warmerda
and watch the world go round - Rush | Geospatial Programmer for Rent
OSRS PRoject PROJ Discussion List
To Subscribe: send a message to majordomo at remotesensing.org with 'subscribe osrs-proj' in the body
To Unsubscribe: send a message to majordomo at remotesensing.org with 'unsubscribe osrs-proj' in the body
To Report Problems: send a message to owner-osrs-proj at remotesensing.org
More information about the Proj
