[OSRS-PROJ] NTv1 (Canadian) Grid Shifts, and proj_def.dat
Brent Fraser
bfraser at geoanalytic.com
Thu Apr 5 13:05:52 PDT 2001
Frank,
I've purchased the NTv2 data. Can I use it with this new version of
PROJ.4 without any code modifications or extensive data re-formatting?
Brent Fraser
GeoAnalytic Inc.
#300 , 700 - 4th Avenue SW Calgary, AB
Canada T2P 3J4
Tel: (403)213-2700 Fax: (403)213-2707
www.geoanalytic.com
----- Original Message -----
To: "PROJ.4 Discussion" <osrs-proj at remotesensing.org>
Sent: Thursday, April 05, 2001 1:11 PM
Subject: [OSRS-PROJ] NTv1 (Canadian) Grid Shifts, and proj_def.dat
> Folks,
> Two items.
> First, I have modified nad_init() to support loading of Canadian NTv1
> grid shift files which are free to use, though lower precision than the
> expensive NTv2 grid shift files. Anyone interested in testing this is
> encouraged to contact me.
> Second, I would like to change proj_def.dat to provide a default ellipsoid
> of WGS84 (really would make it +datum=WGS84). The assumption is that in
> this day and age WGS84 is a better default than clrk66 (normally NAD27).
> What are peoples opinions on making this change? Obviously it could
> cause some problems, but I have been bitten a number of times by the
> implicit appending of clrk66.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
> PROJ.4 Discussion List
> See http://www.remotesensing.org/proj for subscription, unsubscription
> and other information.
More information about the Proj
